Question about Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop
Screen problem The mouse stops moving while I am bussy working and as soon as the mouse does this the sreen become dark in certain sections of the sreen. To resolve this problem I have to restart the computer and this problem occurs about every5 minutes.
    Brigadier General:
  • 6,966 Answers
Hi, if everything is still original with no add-ons or upgrades, then it is most likely that one of your memory is failing. Your computer has a built-in video card that shares memory system. Then replacing the memory should do the trick. However, I must caution you that your particular brand/model has certain limitations to the type/size/speed of memory. You should probably consult a qualified service personnel/professional since this involves opening the case. Should you want to do this yourself, a step by step instruction is available at http://support.dell.com/support/edocs/systems/opgx110/ens/sm/remms.htm. Hope this be of some help. Good luck.
Posted on Apr 24, 2007
Can move the mouse but cannot click on anything
Many times drivers can become corrupt. In some cases when the PC will not work correctly with the mouse upon start up a second time then I would go to device manager and remove it then let Windows find it again and install the drivers again. If that does not work and you have tried another mouse to eliminate a mechanical malfunction, and made sure the plug is well seated,
Try to start in safe mode and see if that helps. I have not had a mouse problem but then I do not use Dell. In cases where I have
trouble, I have always been able to resolve the problem as listed above.
Sep 23, 2012 | Dell Computers & Internet
Mouse never wokred the computer says device is working properly it DOeS not work
Usually they work as soon as you use the cd and install it. You do need the right driver for the operating system you're using. If you don't have the install for the operating system search for micro innovations site and download it, usually under their support section.
Also double check the connections and make sure that the antenna isn't too far away from the mouse. It won't work if it is. Try moving it to another place and see if it works then.
If none of that helps then perhaps you have a defective mouse.
Jun 25, 2011 | Micro Innovations PD7250LSR Wireless RF...
I have an Asus 1201N netbook and my mouse stopped working. Windows starts correctly and I can navigate through the Windows 7 Start panel with my keyboard but the mouse does not respond. What am I to...
Don't think it could be a mouse driver problem since you already said that it stopped working which meant that the mouse was in fact working before under Windows 7 on your netbook. Based on this, here are some suggestions to resolve your unresponsive mouse problem. Basically, you are trying to determine if the problem is due to the mouse or due to the netbook....
1. If you have a wireless mouse, did you try replacing its battery with a new battery?
If the wireless mouse now works with the new battery, your problem is resolved.
2. If you have another laptop, did you try moving the unresponsive mouse to try it there?
If the mouse also does not work on the other laptop, then suspect the mouse is faulty.
3. If you have another mouse, preferably a wired one, did you try it on your Asus 1201N?
If the replacement mouse works on the Asus 1201N, then suspect original mouse is faulty.
4. Finally, just an observartion, the Windows 7 mouse driver expects a Microsoft mouse and if you click on Control Panel > Mouse, the Mouse Properties window will say No Microsoft USB Mouse Detected but this should not prevent the use of any generic mouse.
Mar 28, 2011 | ASUS Eee PC 1000HE Netbook
Device turns on but will not move the mouse
Observe to ascertain that is a wireless optic. usually wireless optic mouses require the adaptor section of be pluged to the computer to capture the signals. Also, mouse should light up soon after batteries were inserted in compartment. Power off the computer completely, repower on should capture the new settings.
Feb 06, 2011 | Kensington PocketMouse 72214
Will not connect..its not in sync with my pc
Hello
Turn the switch to the "On" position, located underneath your mouse if your mouse has a switch.
Restart your computer to have a fresh starting point for troubleshooting. Sometimes, just restarting your computer can resolve issues you have with your HP wireless mouse.
Move your HP mouse about 39 inches away from your receiver.
Unplug your USB receiver, if you have one, and wait about 10 seconds.
Replug the USB receiver into another USB port, closer to your mouse if possible, then resynchronize your mouse and receiver.
Press and hold the connect button on your receiver, while plugged in, until you see the LED light flash.
Hold and press the connect button underneath your mouse until the LED light on the receiver stops flashing.
Check to make certain the button under your mouse does not get stuck in the depressed position and releases. Also, make certain you complete this resynchronizing process in 60 seconds, or else you must start over. Your mouse will now have a new identification number from resyncing.
Unplug the USB receiver, wait 10 seconds, then replug the receiver firmly into the USB slot, pushing it in entirely. You will notice the receiver's activity light turn on, then off in the next five seconds.
Press the connect button underneath your mouse until you see the activity light turn on again on the USB receiver.
Check to make certain the mouse connect button does not remain depressed when you release it.
Nov 14, 2010 | HP Wireless Optical Mouse
Logitech MX mouse is irratic. when you move across the screen it moves, stops, moves, stops etc. If you move across the screen in a straight steady line it will do it in steps. Kinda like the computer...
Typical behavior for many wireless mice. Try using a piece of white copy paper instead of a mouse pad or whatever if you already aren't. Surface makes a difference with functionality and battery life with a wireless.
Hope this helps.
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | Logitech VX Revolution 931690-0403 Mouse
My mouse works when it wants to.
It could be interference or distance from the receiver.
Try moving the receiver. Regular wireless mice can become unstable even at short distances.
Feb 10, 2010 | Logitech V450 Nano Cordless Laser Mouse
My Logitech Medialife mouse will suddenly stop in its ability to move the cursor; and when it happens, the Touchpad also will become inoperable. Which leaves me with only one option: shut down my PC...
Can you notice if the mouse stops when using a certain program or while you've been on the pc for a length of time. When hardware stops it could be conflicts with other programs, a driver issue, battery. If your mouse worked without problems not long ago I'd first try a system restore back to the time when it worked. To do a restore click on programs, accessories, system tools and the system restore. Pick a day on the calendar before when the mouse was working and let the pc restore back to that time. It will restart then see if it works for you.
Thanks,
Henry
Nov 15, 2008 | Computers & Internet
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
Oct 10, 2007 | Logitech Cordless Mouse
Dell OPTIPLEX GX110/200 PIII-866MHz 256MB 20GB (PCPIII866DELL) PC Desktop Logo
26 people viewed this question
Clive
Clive
Alun Cox
