Question about Gateway DLP56TV 56" Rear Projection Television
DLP lamp won't stay on
I have a Gateway 56" dlp same as the Vizio RP56.
When I turn the tv on the lamp will only light up for a couple seconds then turn off. I have cleaned all the fans and they all turn on. I checked the color wheel and that turns on. The status indicator lights on front show a lamp error but I replaced the lamp and it still does the same thing.
  • 3 more comments
  • BLUEHILLS55 Jan 03, 2009
    I have the same problem. I have been web searching for a service/repair manual & had no luck.
  • dkdirt63 Jan 05, 2009
    Hey that's a better manual than I found for the Vizio. It was only 26 pages and worthless. I'm not sure how that lamp works if the ballast just lights it once and it stays on or if it keeps igniting it, My lamp comes on for maybe 4 or 5 seconds then turns off and then the tv restarts several seconds later.
  • ILYA3D Feb 07, 2009
    Did you guys found how to fix that problem? I have same thing with my TV...Please share your expirience.....
  • genevadudley Mar 10, 2009
    Brand new bulb not lighting on Vizio rp56 DLP
  • ILYA3D Mar 18, 2009
    Hey, guys! Two things I found out. I checked my lamp phillips E23 is 100v. That was the problem!!! Ballast is 100V-120V. That is why my Tv was shooting down after couple minutes and restarts it self. So. I bought new lamp OSRAM 100v-120v, now it works great!!! But it always budd...Now TV after 1hour of work shows weird colors like negative photo picture and has some sound, than again shots himself. I'm for sure this is Optical Block(color whell). So, If anyone had the same problem share some experience with us. Sorry for spelling.
After 2 hours of web searching, I finally found a service repair manual. Below is the link to the site. After scanning this manual, beginning on pg 61 is the troubleshooting guide. It sounds like the problem is the ballast if the lamp checks out ok. Let me know your thoughts after looking at this and hopefully the both of us can work together & come up with the right solution on how to fix our problem with our 56" Gateway DLP.
http://www.eserviceinfo.com/downloadsm/28163/Gateway_56InchDLP.html
Posted on Jan 03, 2009
3 Suggested Answers
  • 4234 Answers
SOURCE: replaced bulb for Vizio rp56 DLP got power no light
There are interlocks that will prevent the set from starting if the lamp is not installed correctly or if the access door is not closed properly. Either condition will result in a "lamp error" indication. Try reinstalling the lamp being careful to be suer that it is seated properly. Also make sure that the access door is fully closed and aligned. If you continue to get the lamp error, it is possible that the ballast circuit is defective. This is the part that generates the power to "fire" the lamp.
Keep us posted.
Dan
Posted on Mar 10, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a JVC 56 DLP TV. It made a poping sound
Lamp, Call FOX 1-800-227-5369 If they dont have any in stock Call Mats Electronics 1-800-628-1118
Posted on Dec 31, 2009
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
Buzzin sound not fr the lamp on a scenium hdtv
On DLP TV that sound is probably the color wheel bearings.
Apr 15, 2010 | V, Inc. VIZIO RP56 Rear Projection...
I have a Samsung HL56A650 DLP TV. The Standby/Temp and the Timer lights are blinking. It will turn on and then shut off. When it comes on the picture is fine but it only stays on for a few seconds. There...
The description sounds like a protection mode has been activated and the smoke obviously confirms this. Sounds like it will need to be inspected by a service technician and could get expensive
Mar 19, 2010 | Samsung HL56A650 56 in. TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung DLP hln567w tv has NO picture on all
If the Lamp ignites and stays lit, but screen is completely black, not even the on screen display, then it is likely a bad DMD board.
If the lamp ignites and then turns off after a couple seconds then it is likely the color wheel is seized.
If the lamp never fires, but the TV clicks a bunch of times, then it could be a bad Ballast or the Lamp itself.
Sep 18, 2009 | Samsung DLP HL-P5663W 56" TV
Replaced bulb for Vizio rp56 DLP got power no light
Keep us posted.
Dan
Mar 10, 2009 | V, Inc. VIZIO RP56 Rear Projection...
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Gateway DLP56TV 56" Rear Projection Television Logo
392 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
