Question about IBM E74 17" CRT Monitor
Crt computer monitor model 6332-03n
It working normal for the first 20 minutes after that the screen becom blanking and the power of horizontal output make strange sound. but when the input signal disconnect the monitor display show (no signal) and the power work normal without any problem.
    Brigadier General:
  • 6,966 Answers
Hi, you can try lowering the screen resolution, the color quality and the screen refresh rates. Work from there and observe each setting/increment. soon as the monitor quits, press escape to revert to previous setting. I get the impression that you are familiar with electronics, the problem is your monitor horz. freq is playing catch up and eventually fails. Lowering your PC setting then might do the trick. To lower the settings, right click on desktop, properties, settings tab & advance button - Monitor. Hope this be of some help. Good luck
Posted on Apr 24, 2007
  • Louie  Role
    Louie Role Apr 24, 2007
    In addition, if the monitor will not let you do the previous, start in Safe Mode and do the same.
    This is of course assuming that nothing is wrong with the monitor.
    Regards.
Blank screen but it has sound, when i turn on there is a horizontal line in the center of the screen, before it goes blank but still have sound, i already check all the resistor on both power supply and...
Your fly back, horizontal is in good condition but the possible fault is in the deflection coils or the deflection correction , pin correction section or the hirizontal width coils.
Please check them one by one as they are found along the sides of the flyback sections. check the continuity of the horizontal coils, it can also be a leak/burnt coils that can cause this problem.
Nov 02, 2010 | Sony KV-20M20 20" TV
My samsung syncmaster 794 monitor light is blinking but monitor not get on
If you tested that to another working CPU but the same problem before, i think that monitor has a problem in horizontal section, check the B+ atlaest 175v if is it normal the power supply is ok, check the H.O.T horizontal output transistor, remove or hang the 3 pins then power on the monitor, if the led did not blinking the H.O.T has fault may be leak,open or shorted.
Sep 28, 2010 | SAMTRON 55V 15" CRT Monitor
After using the monitor for more than 20 minutes eyes become watery and burning sensation starts. I am afraid if it causes heavy radiation. ...
CRT screens emit low levels of electromagnetic radiation, mainly from the back of the monitor. LCD a lot less emit less electromagnetic radiation. The backlight from a LCD screen is provided by a CCFL lamp, this is a very small fluro tube about 2mm in diameter compared with a 20-25mm normal fluro tube.
I do not think the LCD is the cause of your problem, I suggest you consult with an EYE specialist about your problem.
For details of electromagnetic radiation of CRT and LCD screens/TVs, please click on this link :-
http://www.lcdtvbuyingguide.com/lcdtv-crt.shtml
Sep 14, 2010 | LG Flatron L1515S 15" LCD Monitor
HP MX705 ON MY DESKTOP JUST WENT BLACK AND BLANK. THE POWER LIGHT JUST BLINKS.
a CRT monitor  just like a CRT television when it fails may still have a light on the front panel operate   you probably had a catastrophic failure  usually small electrolytic capacitors near the horizontal output transistor dry up an cause the transistor to fail  the voltage regulator may also fail in the process
Nov 07, 2009 | HP mx705 17" CRT Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Horizontal out always damage in minutes
Probable defective flyback (horizontal output transformer).
Mar 10, 2009 | ViewSonic E70f 17" CRT Monitor
Crt monitor problem
try to check the pincusion...
Jun 27, 2008 | AOC LM729 17" LCD Monitor
Display problem
pls check all the electrolytic cap after the secondry power and electrolytic cap to in/output the vertical ic and at horizontal cct.
thanks.
Dec 17, 2007 | LG Studioworks 700S 17" CRT Monitor
IBM E74 17" CRT Monitor Logo
412 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
