Home | Microsoft | Office Outlook 2003 for PC | Blackberry keyboard pro...
Microsoft Office Outlook 2003 for PC
Problem for Microsoft Office Outlook 2003 for PC
Blackberry keyboard problem
By knortman304 on Dec 28, 2008
All of a sudden, my blackberry keyboard has ceased working. None of the buttons other than the rollyball are working. And the rolly track ball will only allow me to scroll, not select (e.g., select anything). I have tried taking out the sim card, the battery etc. Please help! Thank you
Same Problem
May 24, 2009
-   Phone was working fine, then suddenly no keyboard use. Trackball works, but side keys and keyboard keys do not. Cannot even turn it off. Have tried removing battery, but problem remains. -   BBSucks
Feb 23, 2009
-   this is the THIRD phone in less then 2 months the phone works fine and then BAM no buttons work, not side keys nothing. they act like they have never heard of the prob at warrenty place but look at the other postings all over the place only way to fix it get a new one and even that doesnt help :(-   Guest
Best Solution
posted on Jul 07, 2009
Helpful)
jaydmclean
Rank: Guide
Rating: 92%, 12 votes
I found a solution to the keyboard malfunction problem which has not been discussed on any forum I have looked at. I apologize if this has since been added to this thread as I have not read it in a while. Unfortunately I am pressed for time, and want to make sure others benefit from my discovery. Sorry for the bad Netiquette.
As with many other people I was extremely frustrated by the fact that so many support forums had people who had tried all the solutions, but like me had persisting keyboard issues. So I took a day and tried EVERYTHING I could think of. These are two solutions that I have found to two different symptom sets. I have only tested Bell Blackberry Curve 8330s.
I have now tested these solutions many times on several different Curves. Note none of these phones responded to the other solutions: (Remove battery for 30 seconds, blow dust out of keyboard, preform soft reset, delete archived msgs, update OS, etc..)
[COLOR="Red"][B]Symptom set #1[/B] - “Keyboard and side buttons not responding… only Track Ball scrolling (but not push selection) responding”[/COLOR]
[COLOR="Green"]
[B]Solution:[/B]
[I]This seems to be somehow caused by a function of the Scroll Ball locking out or blocking the input signals from the other buttons.[/I]
1. Turn off your phone by removing the battery
2. While battery is out of phone remove Track Ball
a. First remove the silver disk around the Track ball. This pops out easily with your fingernails
b. The ball will now simply fall out if you turn over the phone. (tap it if need be)
c. **take note of the orientation of each of these pieces so that you can put them back in the correct way. If you lose track of the way they came out, they will only go in the correct way…. Just don’t force anything.
3. With the Track Ball out of the phone, put the battery back in and power up the phone.
4. Check to see if the keyboard is responding. If it is,
5. Put the track ball back in the phone with it still powered on.
6. Test keys and trackball, it should be working now. [/COLOR]
Note: that it is unlikely that this is simply a result of the battery being removed for more then thirty seconds. I have only tested this on Curves that did not respond to repeated attempts at “the 30sec battery pull”. Each time this worked on the first try.
[COLOR="Red"][B]Symptom set #2[/B] – “Blackberry responds to Keyboard keys producing the wrong letters and pressing Track Ball produces random characters”[/COLOR]
[COLOR="DarkGreen"]
[B][B]Solution[/B][/B]
[I]This seems to be caused by the Blackberry reading the battery as partially charged when it is almost dead. I was able to prove this by testing the battery using another device. Although my phone believed the battery to have some charge the battery was actually almost completely dead.[/I]
The solution is simply to charge the phone. All but one of the times I have used this solution the BlackBerry actually started reading the battery as dead immediately after being plugged in.[/COLOR]
Hope this helps... sorry for the long post.
Jay-D McLean
Edmonton, AB, Canada
Comments:
Jul 07, 2009
- I found a solution to the keyboard malfunction problem which has not been discussed on any forum I have looked at. I apologize if this has since been added to this thread as I have not read it in a while. Unfortunately I am pressed for time, and want to make sure others benefit from my discovery. Sorry for the bad Netiquette.
Symptom set #1 - “Keyboard and side buttons not responding… only Track Ball scrolling (but not push selection) responding”
Solution:
Symptom set #2 – “Blackberry responds to Keyboard keys producing the wrong letters and pressing Track Ball produces random characters”
Solution
Jay-D McLean
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Nov 04, 2009
Not Rated)
einsgoshin
Rank: Apprentice
Rating: 0%, 0 votes
Hello everyone, this problem is cause by humidity, it is solve leaving your blackberrry rest for a while without battery in a dry place. Blackberry has not mention it but it happens a lot, and it only needs a little quantity of your own sweat to put you in troubles.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Office Outlook 2003
Questions and Unsolved Problems for Microsoft Office Outlook 2003
Do you recommend Microsoft Office Outlook 2003 for PC?
Answer
Answer
I am attempting to edit a shared calendar in Microsoft Office Outlook 2003. But it is giving me... (More)
Answer
i want some notes on ms office gor my cllege project
Answer
The user made extensive updates to a Word 2k3 document he received and did a File-Save As. The... (More)
Answer
I Have Zebronic cobra 700 cam but i am not having CD to download
Answer
my inbox.dbx size 1.00 GB but not show in outlook express. plzz help me oyt i have a DBX file i save... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Office Outlook 2003...:
Top Internet and Com... Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Internet and Com... Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
