Question about Pyramid PDVD79 CD Player
Radio does not work
I've double checked everything and the atenna cable is firmly connected, but get no radio reception still. The power atenna fuse cable is not connected to anything. eveything else works DVD and CD, but no radio
    New Friend:
  • 57 Answers
Put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Posted on Jan 10, 2009
I have a Sony Mu-te-ki KM7500 7.2 and the power amplifier won't turn on. Everything is connected right and the fuses are good. I lost the system control cable and brought a 3.5mm mono to replace but it's...
take a test light to the the red and yellow wire on the back of the radio and see if you getting power to the radio. do the same to the amp. Double check all your wiring.
Dec 01, 2013 | Car Audio & Video
Am-fm doesn't work on radio 2001 tahoe, everything else works, what could be the problem
Antenna connection is the place I'd start with. Something is wrong with the cable or the connector.
Aug 23, 2012 | ACDelco 2001-2006 AC DELCO-FW311 Chevy...
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
My Aux input on the radio does not work when I plug in my iPod. I've checked the fuses and replaced my miniphone plug cable, but still nothing. Any ideas? 2007 Tundra double cab 4X4 long bed 4.7 L
Fuses have nothing to do with it plug another type of player, radio, cd, etc into it. Your IPOD output may not even work.It may be shop bound (your radio).
Jun 15, 2011 | 2008 Toyota Tundra
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
My husbands 2008 chevy truck's suddenly lost radio reception. everything is just garbled sound on all bands.
Check antenna connection on rear of radio. (It's a large round cable that pushes in rear of radio)
Feb 26, 2011 | Chevrolet Silverado Cars & Trucks
I have a basic 40-channel cobra cb radio and 2 four foot firestik whips mounted in the stake holes of my truck. I have dual 18 ft. coax connecting the two which is ran through 2 small holes near my door,...
You should check the coax cables for damage . ALso, did you attach the PL-259 connectors yourself to the coax cables? They can be tricky. You need to check for loose or bad connections between coax cable and connector.
Of course it could be the radio itself went bad on you. Check this with a friend; when you connect his radio to your antenna system, does everything work then? Hope this helps.
Aug 23, 2010 | Radio Communications
1997 toyota corolla car radio. CD works ok but no reception from radio. All appears ok in display with channels showing and all channel change/scan functions work but no sound. Sometimes static is audible...
First of all have you connected a good antennae. Please double check this out if the antennae cable is shorting with the body ground. If possible use an external antennae wired to the set. If this wont help, then we have definately an issue within the front end of the radio section. Check within the set after putting the mode to Radio for any detecction of EMI. Use a signal injector if you can to trace the signal back from the preamp audio to the radio IF. If you get a response you might have a failed IF processor. Replace if you are able to do so.Initially fix the frequency to the most powerful channel and shake wires or connectors to get a reception. if so solder the area in question.You could also put the Radio on for some time to check for any capacitor electrolitics that have reduced in life/value. I hope this helps. Good day
Jul 08, 2010 | Car Audio & Video
Power atenna and stock radio
id say u maybe of blown a fuse or lost your ground
Oct 13, 2009 | 2002 Oldsmobile Alero
Pyramid PDVD79 CD Player Logo
111 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
