Question about Canon EOS 40D Digital Camera
Canon EOS 40D not working when turned on
When I turn the camera on and push the shutter button, the camera will not focus and it will not make the shutter work and it makes a clicking noise as if it is having an electrical misfiring in the camera.  Do I have the wrong setting(s) or does the camera need to be repaired?
Took to a camera store and they put my lens on a different camera body and lens didn't work. So the problem is the auto focus in the lens itself. It is nothing I can fix myself.  I am now sending it to Canon for repair - hopefully won't need a new lens!  Thanks for the help!
Posted on Jan 03, 2009
    Problem Solver:
  • 14 Answers
I'm sorry to tell you this but you do NOT have anything set wrong. To test my theory turn your camera to full auto. Next make sure your switch on the lens is set to auto. Then just try taking some shots of some objects across the room. If that doesn't allow you to take pictures do the exact same test with a different lens. That way you've taken the lens out of the equation. Sorry I couldn't give you a better answer but I'm pretty sure you'll need to return the camera to cannon.
Posted on Dec 31, 2008
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Oct 22, 2010 | Canon EOS 40D Digital Camera
Will not release shutter on canon 40D
Cannon is notorious for their auto focus and automatic setting to be very discriminant. If you are to close to your subject while in these settings granted your strobe will fire and your flash may flip into position but the shutter just wont work. Cannon is trying to tell you you are too close. You need to back up. If you are trying to get that close up and don't have the proper lens that's all you are going to get.
It is best to go long lens then go for your close up.
Mar 09, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Shutter will fire intermitantly on Canon 40D. It focuses but will not fire but if pressed repeatedly it will fire after several shutter presses. I have changed batteries, I have swapped to other lenses...
This is just a possibility not really a solution: If the AF spot is aimed at a part of the picture lacking details, it cannot focus (all cameras are the same in that respect) Normally (I don't know the canon) there is an indicator to tell you if the camera managed to focus. It can be a beep or a dot which light in the viewfinder. I suspect that in your case you were aiming at something lacking details.
Aug 21, 2009 | Canon EOS 40D Body Only Digital Camera
Camera turns off when pressing shutter button
Sounds like a compatability problem. If available, try a genuine Canon battery new and fully charged.
Jun 09, 2009 | Canon EOS 40D Digital Camera
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
Canon 40D not firing
Try doing a reset in the camera tools somewhere, this fixed a similar problem I had.
Jan 07, 2009 | Canon EOS 40D Digital Camera
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
