Question about Motorola Mobility RAZR V3i Cellular Phone
I bought a memory card for my razor v3 and cannot find a place for it...where is the memory card slot?
  • sujail Dec 28, 2008
    hii. may name is amit i have facing problem in my cell phone
    1. my mobile damy is distroy
    2. Network problem
  • 67 Answers
Http://www.motorola.com/mdirect/manuals/V3_9501A42A.pdf
You plug it in the same spot the charger go's in
this is a link for the manual
Posted on Dec 28, 2008
Why my motorola razar v3 phone can't hold any more song an it,an i cant put no more than 2 song on my phone
Hi, first, your Motorola razor V3mobile phone, has blue tooth and mp3 player facility to recieve and play song which is good. All motorola razor V3 phone has the capacity to receive song into the phone, but does not have the capacity to with hold much songs.Why?
Because all Motorola razor V3 phone does not have and external memory slot to accommodate more extra song on the phone, But it has an internal in-built memory to store data in the phone.
The input memory has the capacity to store data,like music, videos,pictures and so on, But the memory which is the "internal memory" of the phone only has a limited amount of data it can carry in it.
So that's why you can not put in too much data inside the Motorola razor V3 phones.
You can also put more some more music inside the phone by managing the internal memory of the phone by using a converter to convert the music files into smaller bit rate.
Normally music bit rate is always 128kb,but you can reduce it by converting it to small sizes of bit rate precisely 64kb or 32kb.
Warning!!, when you reduce the bit rate of a music,it might not have the same quality of sound it has before you converted it into a smaller bit rate.
Hope it helps.
Thank you for using fixya......
Dec 29, 2010 | Motorola Mobility RAZR V3
I bought a memory card for my v3xx razor phone with At&t i do not know how to get it to work. I do not have a camera to put it in to take a picture. How can I do it with my phone only?
You must not have a v3xx, because the v3xx uses a mirco sd card
and the slot is next to the sim card slot.Also the v3xx has a camera,
and there is no option to get this model without a camera.
The v3 does not have a memory card, but has camera also.
If you do find the slot,if you have a v3xx,then go to your menu and then open connection, then open,phone status, then scroll down to
storage devices,open it, should be left top button, pick options,now you should see,details,rename,format, format the card, this should allow the phone to see the card. There are some brands that just don't work with a phone. I have always used kingston. I have around 12 different type's and they have always been a great card.
Feb 17, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Format memory card
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jan 01, 2009 | Motorola Mobility RAZR V3
Memory card installation
hi,
does your motorola Razr have a Memory Card Slot?
is you Razr model is V3re or V3 only.. (this models doesn't have MMC slot)
is your razr is V3i or v3x or v3xx then the MMC slot is located at the back closed to SIM card.
Jun 09, 2008 | Cell Phones
Memory
Unfortunately the V3 does not have a meory card slot and it can't be added. Sorry...
May 28, 2008 | Motorola Mobility RAZR V3
Unlock Subsidy code for Razor V3 Phone
Try mobile2mobile.net, unlockitnow.com or take it to a mobile service center to have it unlock there for a small fee.
May 24, 2008 | Motorola Mobility RAZR V3
Motorola Razor memory Card
Which slot are you putting it into?
Jan 04, 2008 | Motorola Mobility RAZR V3
Razor memory card
The regular V3 does not have a memory card slot.
Dec 18, 2007 | Motorola Mobility RAZR V3
Razor memory card
The memory card goes next to the battery. if you take the battery cover off and take off the battery then you will see a little slot located at the center of the phone on the back. you can only put the memory card in if the battery is off.
Nov 17, 2007 | Motorola Mobility RAZR V3
How do i download mp3 ringtones to my phone?
If it is Only Razr V3 then probably youdon't have memoty card slot and the sadest part is it has got only 5 MB of space, which will allow you to store only one or two Mp3 song(s) depending upon the size. You can transfer it through Bluetooth. If it is a V3i model having Memory card slot then it is even easier to down load by using Card Reader connected to PC. just drag & drop to the music folder in your memory card. In a memory card you can put lots of songs depending upon the size of your card, say 128MB can hold upto arround 30 nos of songs. Yes you can put choose the Mp3 as Ring Tone Also.
May 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
