Question about Haier HWF05XC5 Air Conditioner
Problem in the power Plug AC doesnt turn on
I have a Haier HWF05XC5 Air Conditioner (the one with the switches) > The problemi I have is that whenever I plug it in the plug "trips off". What I mean is that in the big plug part it "turns off" like if it was testing. I've pushed the reset button and when I plug it in, it does the same thing. I've even tried plug it in with the reset button pushed in, turned off or even reseting while plugged and the AC still doesnt turn on.
  • 334 Answers
That means you have a short to ground somewhere in the system. They can be a pain to track down. You must have a volt/ohm meter and check each component and part individually untill you find the short.
There is a small chance that the GFCI is bad itself.(The part thats poping off and has the reset button.)
Posted on Dec 28, 2008
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
No water drains from unit. is this okay?
According to Haier, that is not a problem. However, I would recommend that outside of the unit, be tiled down 1/4". This will allow the condensation pan to drain, if it becomes overly full.
Jun 28, 2011 | Haier HWF05XC5 Air Conditioner
My haier window A/C won't drain and i can't seem to figure out where the water is actually coming out
It is coming out of the evaporator and probably your drain line is clogged I use a small wire brush to clean them out.
Jun 04, 2010 | Haier HWF05XC5 Air Conditioner
My air conditioner has power but only the fan works no cool air is coming out is it broken, or can I fix it?
sound like the compressor is not turning on if this is Wall unite they are worth investing money into buy anther one.
Jul 07, 2009 | Haier HWF05XC5 Air Conditioner
Need replacement filter
a few dollars. mske your own with filter material from the hardware store.
Jun 02, 2009 | Haier HWF05XC5 Air Conditioner
My HWF05XC5 is not cooling my room
Call 1-877-337-3639 or haier units, then the next page haier unit and model #'s.
Jun 17, 2008 | Haier Energy Star ESA3183 Air Conditioner
Furnace will not light, but there is gas to the house
This problem will need to broken down in several steps. First, reset all the breakers that operate the furnace and ac. Turn the thermostat to on and the ac to off and see if the furnace blower starts. Get back with me.
Aug 12, 2007 | Haier HWF05XC5 Air Conditioner
Will not start
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3632 Hope that helps! ;)
Jul 27, 2006 | Haier HWF05XC5 Air Conditioner
Haier HWF05XC5 Air Conditioner Logo
540 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bonded Repair
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
