Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Default Input in Timer Settings
I am trying to set up the TV timer on function so that it will turn onto the HDMI input. My cable box is connected in this manner. The only options provided are "analog" channels or "digital channels". Since I do not have the cable connected into the CATV IN, there are no digital channels to be scanned or found. Is there a way to set the default input to the HDMI input of the television (Video 4 in my case)? Thanks.
2 Suggested Answers
  • 84 Answers
SOURCE: On Timer - channel selection
The on timer will only work for a channel on this model not for any other inputs
Posted on Mar 23, 2008
Pioneer 5060hd no picture from cable box with hdmi on input 1&3, normal function with hdmi from xbox. Checked cable box, it works well with other tv. Any help to diagnose the problem
I assume that you enabled hdmi ports within settings.
I would connect box to another TV and within settings in box make sure that box outputs either 720p or 1080i.
Your TV doesn't accepts 1080p .
Mar 04, 2018 | Pioneer Televison & Video
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
Why doesn't my Emerson lf501em4f not recognize cable box HDMI?
Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
Sep 28, 2014 | Emerson Televison & Video
Automate On/off for longer than 6 hours and for HDMI input
I would buy a inexpensive timer you can program to turn the TV off and on. Plug the TV into the timer on the wall outlet and Voila !
Jan 30, 2014 | Sony BRAVIA Televison & Video
Model 6626lct turns picture off in ten minutes.
This can happen for 2 reasons. One is that some TVs are equipped with a set up that will turn the set off if no input source is detected ( cable, antenna etc...) Check all connections. The most likely cause is the TIMER settings. Use your remote to access your menu, then TV settings, then into Timer (sleep timer). Set the sleep timer function to off ( or "0" on and "0" off) This should do it.
Jan 08, 2011 | Sylvania 6626LCT 26 in. LCD Television
CABLE BOX HDDVR IT's NOT WORKING WITH HDM1 in put. I have to use av1 source with 3 wire cable. Comcast tech saying it is tv problem.
I am not with Comcast, but rather a much smaller family owned cable company.
You can check the user settings of the box to verify it is in the HDMI mode. Depending on what type of HDDVR you have that is.
For Motorola 62XX and 64XX models follow these steps to check.
1. make sure that your HDMI cable is connected to both the TV and the cable box.
2. Turn TV on, and verify it is on the proper input.
3. Turn cable box off.
4. Press menu button on remote or front of cable box.
5. A user settings menu will appear on the screen.
Note: if it did not appear you may have to connect another type of cables to continue.
6. Information displayed should be set to what your TV set is capable of. Most HDTV's will be set to the following:
16:9
1080i
480i
7. If you see additional HDMI settings as the forth item your TV and cable box are communicating across it, if not try unplugging both the TV and cable box and/or replacing the HDMI cable. Enter the additional settings by pressing the right arrow on the remote.
8. Change DVI to HDMI.
9. Press power to exit the user settings menu.
10. Turn cable box on, and switch TV to HDMI input if not already on it and see if the picture is coming in now.
Note: if you think that you messed up in the user settings you can always restore default settings by following steps 1 through 4 then press up arrow once and right arrow once.
I hope this helps you cable customers, as we appreciate your business unlike Dish and Direct!
Cheers!
Jun 18, 2010 | Philips 47PFL5704D 47 in. LCD TV
Mar 04, 2008 | Sony BRAVIA KDL-40V3000 Television
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
