Question about Motorola Mobility MPx220
How to reset my phone?
I'm not sure what's wrong with my MPx220, it was corrupted while i'm using it and the display went blanked and hanged up.and i tried turning it off but won't work. so i took off the battery and put it back on and turned it on again but it didn't reboot- it won't start up anymore.i will appreciate your kindness if you have any suggestion on what to do with my phone...
  • ernestphat Jun 24, 2008
    I AM IN GHANA AND I AM USING MOTOROLA MPX220 CINGULAR .I USE THE PHONE JUST A DAY.THE NEXT I WOKE UP AND THE PHONE WAS OFF.I RECHARGE AND TURN IT ON,BUT WHEN I TURN IT ON ,THE PHONE TRADEMARK APPEARS ON THE SCREEN AND NOTHING CONTINUES THEREAFTER.
Try updating your ROM file on Motorola (ex 1.53 Aisan rom)
Go to http://forum.surrealnetworks.com/ for more informations
Good Luck!
Posted on Mar 06, 2008
Good Luck!
I tryed 1 is stil corrupt.
Posted on Dec 10, 2007
YOU COULD TRY THE MASTER RESET. INSTRUCTIONS....[1]TURN OFF THE PHONE [2]PRESS AND HOLD DOWN THE BLUE BUTTON AND WHILE PRESSING THE ON BUTTON. [3] THE PHONE WILL ASK IF YOU WANT TO MASTER RESET CLICK ;YES' OK. TRY YOUR LUCK.
Posted on May 03, 2007
My nokia2730 blank display
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 07, 2011 | Nokia 2730 Cell Phone
Mymotorola mpx220 says no service everytime and it had like a 2 hamlf moon sign next to service antena and i tried 10000 times to master reset after pressing yes it says processing and after 2 sec it shuts...
MPx220 - Master Reset How do I do a Master Reset? To do a Master Reset:
  1. Power the phone off.
  2. Press and hold the BLUE action key.
  3. While holding down the action key turn the power back on.
  4. You will then get a prompt asking for confirmation of a Master Reset.
Note: This will NOT delete the file manager but all memory contents and phone settings will be erased. Please recomend that any data be backed up before performing a Master Reset on the MPx220.
May 12, 2011 | Motorola Mobility MPx220 Pocket PC
My n95 screen appears white blank , and i dont know how to fix it ? whats wrong with it? and can i do anything to fix it ?
Mar 16, 2011 | Nokia N95 Cellular Phone
I installed lots of theme in my Nokia E63 after installing one of the theme, the screen went blank white, and I can only see the battery meter and signal meter. The rest is blank white. I restarted it,...
The phone has hung up because there are some errors in the installed software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
Mar 16, 2011 | Nokia E63 Cell Phone
About two weeks ago my n96 screen started to go completely blank but would come back to life after some time,but now it went completely black blank since yesterday and hasnt lit upsince then
try to format with the following link
Feb 24, 2011 | Audio Players & Recorders
When starting the 'Nokia' name comes up then screen goes blank and turns off
The phone is hanging up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jan 25, 2011 | Nokia 6500 Slide Cellular Phone
Memory card
See that the memory card is a branded one or else it could effect your phone .....................
Feb 16, 2009 | Motorola Mobility MPx220
Does not start
change the rom or hard reset,to do hard reset first press the big blue button and hold it press and then press the power swich,the message master reset will apear and choose yes.By doing this you will loose everything on your phone
Apr 05, 2008 | Motorola Mobility MPx220 Pocket PC
Motorola mpx220
First try a other battery from a friend with the same phone, if the problem is solved, the battery is faulty, If the problem is not solved, the battery connector is faulty, you will have to take your phone to a repairman to have this repaired. Hope this helps Regards
Aug 07, 2007 | Motorola Mobility MPx220
My MPX220 internal LCD broke
I would personally suggest going to ebay. They carry many replacement parts for cell phones such as the Flex cable that you need, and are quite inexpensive as well. I guess figuring out how to install it is the tricky part. Good Luck!!!!
Feb 11, 2007 | Motorola Mobility MPx220
Motorola Mobility MPx220 Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
