Question about Reddy Heater-30-55,000 BTU Variable
70,000 BTU Reddy heater - runs - but it puffs smoke
Also need to know how to change the spark plug on it
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
Had my kereosene 90,000 btu heater running yesterday and shut it off.plugged it in today and all it does is spit raw fuel out the front.i take the spark plug out and try to ground it i can't see any spark...
ruppguy,
All the time.
You have a classic reddy heat problem. They use a system which sets the fuel pump pressure with bleed air. Comes out the back where there is a screw. If the pressure is not 4.5 psig the pump will pump too much or in your case too little fuel. This happens when the air filter plugs and changes the ratio. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts at the best price.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Space heater is smoking smelling
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Nov 10, 2010 | Reddy Heater R70 Portable Forced Air Space...
I have a 60,000 btu Reedy Heater runs 5-10 min then shuts off restarts black puff of smoke bad plug ??
Check the fuel filter on the units as well as the inlet and outlet filters on the back of the motor.
Watch the nose cone and see if the end starts to loose the glowing orange color before it quits.
If the unit slowly looses the color then you have a fuel problem but if the unit just quits at full heat then you could have a electrical problem.
Typically the spark plugs on these heaters don't go bad.
Oct 13, 2010 | Reddy Heating & Cooling
Puffs smoke when starting
You may have contaminted fuel, a dirty nozzel, or you may need to replace the fuels. Insufficient air flow also can cause this. You can go the manufacturers webite a www.desatech.com . They offer service manuals that should be able to assist you. Thank you
Jan 27, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
Kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-30-55,000 BTU Variable Logo
426 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
