Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen is longer any channel using comcast
Its the same if its procrastinated in 480 or 1080
The input setting was on cable input vs the hdmi input. The cable input elongated the screen
Posted on Dec 28, 2008
My Comcast Proscan HD TV has a small screen on non HD channels.
I have 2 pro scans Comcast hd. On Comcast remote small button ( for me Its small circular button bottom right) HD ZOOM. (enter above it)
Aug 30, 2012 | Televison & Video
Digital vs analog
Yes but you would need a second set top box, that can pick up the channels.
Jun 16, 2012 | Panasonic Televison & Video
I had comcast before but now i don't ,don't use a converter box and somehow I was getting cinemax and other channes on the tv,now i am not I auto programmmed the tv again and mess the the channels...
> I had comcast before but now i don't, don't use a converter box and somehow I was getting cinemax and other channels on the tv
Comcast was providing Cinemax and many other channels as part of your paid services and you will not receive these unless you are a subscriber. There is a good selection of free broadcast channels unless you live outside city areas. If you do, you will then need an external antenna and probably an amplifier to get more distant signals. Auto programming will not find the channels you were receiving from Comcast so there will be only accidental channel duplication; for example, if your former channel 10 was NBC, it may be channel 7 when receiving signal from an antenna.
There are essentially no more 'Analog' stations still broadcasting, they are now all 'Digital.' The abbreviations 'Std' refers to the aspect ratio (H/W) of the picture area and 'Hrc' and 'Irc' the available resolution or how many pixels and lines on the screen.
Aug 28, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Panasonic viera 42 inch plasma, comcast digital cable. screen goes totally green. switch to comcast guide, green disappeared and switched channels, then back to original channel and all was normal. it...
It sound like you are using a component video connection to the TV, which is of variable specification. Try a different type of video feed from your Comcast box
Jan 27, 2018 | Panasonic Viera TH-42PX80U Plasma TV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Jun 18, 2009 | Zenith VCS442 VHS VCR
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
No Image on Screen
Since you have a comcast info on screen your system is fine.Call comcast to fix your box.
Mar 02, 2008 | Televison & Video
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
