Question about Whirlpool LGV4634JQ Gas Dryer
We must wait one hour to dry 2nd load
Kenmore 11086983110. First dryer load of the day comes on and drys great. We start hearing a clicking noise and dryer stops. After waiting one hour it will start again??
  • Danny Clark
    Danny Clark May 11, 2010
    Is this gas or electric?
    Have you checked to make sure there is no lint buildup in the filter area or the exhaust tube?
  • 115 Answers
You have a bad motor the internal overload is cutting it off when the motor gets hot and that is why it takes about a hour for it to cool down before it will come back on the fix is replace the motor which is very expensive or buy a new dryer
Posted on Dec 28, 2008
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Mar 12, 2010 | Kenmore Dryers
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer not Starting Consistently
You have a motor that is gone bad.
May 09, 2009 | Dryers
Water comes into machine when on dryer clothes tak forever to dry
This machine drys by intermittently spraying a mist of cold water into the warm, moisture laden air traveling in the tube at the back right side of the machine. The cooling of that air stream causes moisture to condense and join the added water, which is periodically pumped out the drain. It takes a long time, and the clothes are not as "dry" as you may be use to with a conventional dryer. Never try to dry more than a half tub of laundry. These machines are great if you have small amounts of laundry to do, have limited space, and / or do not have 240 volts, (or a gas supply) and cannot do an outside vent. Don't plan on doing more than two loads per day. (one in AM, one in PM) Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Jan 17, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
