Question about Acer TravelMate 270XV Notebook
Acer Travelmate 270 - battery problem?
I am experiencing a couple of problems with my laptop, my original battery seems to have a memory, so I need to purchase a new one. The first replacement I bought was not charged and would not accept a charge, I kept it charging over a weekend with no luck, so that was returned. I then received another replacement which was fully charged when I received it. I used it a couple of times, but during short use (5 minutes) the laptop would shut down without warning, even though the battery was showing a full charge. Could it be a couple of faulty batteries or might my laptop be at fault. If so what is the best course of action.
    Scholar:
  • 121 Answers
IT sounds like your laptop or powersupply/charger is at fault. Try to use a different charger, and if possible use your battery in a different computer. That way you can narrow down where the problem is. It might ba a faulty connection where the charger is connected to your computer. To check this out, try running the computer on AC without the battery installed. If it suddenly shuts off it's a problem with your powersupply or possibly the connection plug in the cimputer.
Posted on Apr 24, 2007
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
Aug 06, 2014 | Acer Computers & Internet
How to replace batteries in batterypack of travelmate 270?
http://www.battdepot.com/us/model/Acer/TravelMate+270.aspx?gclid=CJD2oLTw_L8CFQmoaQodn2EAQw
Aug 05, 2014 | Acer TravelMate 270 Laptop Charger...
I just can't find the audio and video drivers for a acer travelmate 272, can you help me?
The travelmate 270 series should include your laptop, drivers are available at
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=195
if you need further assistance please let me know before giving feedback.
Thanks,
Ekse
Feb 22, 2011 | Acer TravelMate 272XC Notebook
How to format acer travelmate 270
Insert the original "System Restore" CD/DVD disk.
Restart the computer, and tell it to boot from the disk, rather than booting from the usual 'C:' drive. Click to reinstall Windows, from "scratch'.
Sep 15, 2010 | Acer TravelMate 2700 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Acer travelmate 2300 - power on but as if BIOS did not start
Open the memory cover from bottom of the laptop if you can find. And re-plug the memory chips carefully..make sure it be plug in properly. and try switch on again.
Nov 05, 2008 | Acer TravelMate 2300 Notebook
Memory
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Acer travelmate 270
I had the same problem and it was my battery - i would strongly suggest getting a new one, doesnt need to be an ACer - it could even be a generic one- just as effective.Try www.cellphoneshop.net, they sell cheap batteries.
Aug 31, 2007 | Acer TravelMate 270XV Notebook
Dismantle Acer travelmate 270 Laptop
Caution is advised, as getting everything to work again after you put it back together is normally difficult, especially the screen. You will have to remove all the panels underneath, all screws and look for screws around the screen hinge area, with hexagon heads. There are no instructions on acer notebooks on their site for obvious reasons.
Mar 18, 2007 | Acer TravelMate 270XV Notebook
Display problem on acer 270 trvel mate
It could be a faulty driver, hopefully and not your screen, download driver from here:- http://support.acer-euro.com/drivers/notebook/tm_2200.html
Feb 18, 2007 | Acer TravelMate 270XV Notebook
Acer TravelMate 270XV Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
