Question about Hoover Dryers
Hoover HDV6 Drier on-off switch
The machine will only work if the on-off switch is held in manually. Is this a problem with the switch, or is there a relay circuit that should 'latch'? The switch (part no 0920 1168?) appears to be Normally Open spring loaded. Many thanks R Keith (robin.j.keith@sellafieldsites.com)
tom19511
  • 1601 Answers
SOURCE: Re: no sound on E-machine T5048
download audio driver here.
http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T5048
adjust sound in control panel.
let us know if it works
Posted on Nov 03, 2007
SOURCE: Hoover tumble dryer hdv6
my dryer this model does not get warm?
Posted on Jun 19, 2008
  • 10 Answers
SOURCE: visioneer 4400 usb scanner
here is my solution --uninstal the drivers form device manager unplug the power plug on back of scanner --go to visioneer website and get the xp driver for the 4400 scanner--save instead of running the download ---right click the downloaded installer and click compatable --make to run in xp mode and click OK--install the drivers as prompted when installed restart if prompted then plug the power back into the scanner----instal drivers as prompted --unfortunately --vista wont put the icon in my computer like xp does--the solution is to open program WINDOWS PHOTO GALLERY click file at top then import from scanner etc --the familiar page will come up with your scanner to preview or scan as you did before vista----this is the way i use it on vista home basic and i dont have any problems--hopefully you wont either
bill fae fife
Posted on Nov 28, 2008
Mimito7
  • 128 Answers
SOURCE: What are the oiling recommendations for Consew 199R-1A?
Keith, onthe head of the machine there should be about 5 spots to oil.
1) near wheel on top of machine
2)near the top left hand side
3)) in the middle of those 2
4) open bobbin case , remove bobbin and oil around the rim of where the bobbin sits
5) about 1/2 way between needle and base of machine.
You should blow out machine with canned air and then oil once a month.
Posted on Apr 23, 2009
  • 125 Answers
SOURCE: i need to put a new drive belt on my hoover hdv6
usually two belts one from drive motor and the other a big one to turn the drum. Take the back access panel off and loosen the tension on the motor for the first one ... for the drum belt you have to pop the top of the dryer open (use something like a paint stir stick and a hammer on each front top corner of the dryer to pop open the clips. nothing metal or you will chip the enamel paint)
Posted on Aug 16, 2009
Manual for Hoover Nextra Washer/Drier, HNWF3135
You can download a PDF of this Manual Here
http://service.hoover.co.uk/manuals/HNWF3135.pdf
Oct 07, 2015 | Hoover Washing Machines
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
Hoover dryer manual
never a good idea to run with out earth wire????
which earth wire did you remove heater or motor
if you removed the heater wire and it works
then change the heater
Jan 26, 2014 | Washing Machines
Hi I have a Hoover 5005D drier which was going
I USED A PIECE OF CARDBOARD WRAPPED IN DUCK TAPE TO WEDGE BETWEEN THE DOOR AND THE FRAME. IT WORKED FINE FOR THREE YEARS
Aug 05, 2013 | Hoover ACCESS DOOR-U7069/71 - 35121001
Hoover hdv6 won't dry clothes. When switched on just makes a ticking over sound but drum won't turn. Filter care light comes on but thus has been emptied. Help.
Did you try unplugging and then waiting a minute or two then plugging it back in? If this didn't work try different drying cycles. Have you recently had a power outage while the dryer was turned on? If so when the power came back on it may have fried chips or boards for drying cycles.If all these were not present or did not work call a service tech recommended by Angie in your area
Dec 07, 2012 | Dryers
Hoover drier button won't stay on when pressed, but operates normally if held in
your motor start relay on the motor is bad and you need a new start relay
Apr 16, 2010 | Hoover HDC6 Electric Dryer
The stop button will not stay and makes a buzzing
This sounds just like you have a bad door switch. You check it by taking the two wires off of it and taping them together. Then try the dryer. It should take off and run normally. If so, replace door switch. Good luck.
Oct 21, 2009 | Hoover HDC6 Electric Dryer
I need to put a new drive belt on my hoover hdv6 tumble dryer, how do i do this?
Aug 16, 2009 | Hoover Dryers
--Bad motor run windings
--bad motor switch
These are two possibilities.How old is the dryer. may not be worth it. get the model# from the dryer & price a motor. (new motor cures both of these possibilities)
Oct 29, 2007 | Dryers
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
Marvin
Marvin
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
