Question about Maytag Neptune MDE4000 Electric Dryer
Not drying properly
When using the moisture sensing function my clothes are only getting 80% dry. used to dry them perfectly
  • 318 Answers
You may have lint build up inside the blower duct, where the lint screen goes into. also could be the vent is pinched off behind the unit or could be the vent is just getting plugged up with lint. either way make sure it has plenty of air flow or the units moisture sensor wont work properly.
Posted on Dec 28, 2008
Frigidaire affinity dryer takes long to dry
it could be the tempature of dryer is low but more likely the clothes are not spun dry as used to be .
Mar 05, 2015 | Frigidaire Dryers
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Feb 18, 2012 | Dryers
Our NED7200TW intermitantly won't shut down when the clothes are dry. Every 4-6 loads, it just keeps drying. It stops upon opening the door and turning off switch. the first time this happened, I...
try looking at the moisture sensor strips. usually inside the under the door area. two strips that sense moisture as the clothes roll by. these may be broke, shorted or need replaced?
Jan 19, 2018 | Amana NED7200TW Electric Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
My dryer does not completely dry the clothes when we use the dryness sensing option. It does fine when we use the timer. Is there a moisture sensor that I might be able to replace ?
Dryers with electronic control and auto dry cycle indeed use moisture sensors for the auto drying to work. The problem is absolutely associated with the failure of the moisture sensors, especially when the timed dry cycle works fine. Either the connection of the sensors to the electronic control is loose or the sensors are covered with thin film that prevents it to sense the proper moisture content of the clothes.
Clean the moisture sensor bars thoroughly and make sure its connections are snug fit. Reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. The last thing to look into is the electronic control if all resort fail to address the issue, that is, clean sensor bars and good terminal connections.
Indicate the exact model number of the dryer should you need further or more specific troubleshooting and repair advice.
Jun 12, 2010 | Estate TEDX640JQ Electric Dryer
Clothes aren't dry
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Apr 23, 2010 | Frigidaire Electric Dryer
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Maytag Neptune MDE4000 Electric Dryer Logo
111 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
