Downgrading from windows vista to xp
I have a hp laptop. dv4-1138tx.
it is already built in with windows vista.
but i would like to downgrade it with windows xp.
i have tried ur method of removing the battery and the ram sticks.
but still it is not working.
is there any other options for me to try out next?
thankx.
  • arajeek Dec 28, 2008
    thank you for your comments.
    but i am not sure about the sentence
    'Select R option at Boot options (for recovery Console)'
    please kindly explain to me..thank u
  • ashjames07 Jan 12, 2009
    i have the same problem my laptop is vista and i want to downgrade too. in the BIOS setup there is the mode your drivers are currently set to which would be SATA. to run xp the mode needs to be HDD. once you've done that, boot the xp disk and it should install but not if you still have drivers in the SATA mode.
    my problem is finding the section where this change is made i cannot find it on my BIOS setup. i found a guide for sony vaio's but the screen print didnt match that of my bios setup. my laptop is VGN-N438M/S. what i ahte about vista is not that i cant use it but the excessive amount of RAM it takes up (over a gigabyte).
    hope you have better look finding it than i am. according to the guide one screenprint showed an option you open called: standard CMOS setup and in that section has the drivers and there modes. for each driver click enter on them and they are supposed to change to HDD. my problem is finding that. it will take minutes if it is possible to do it that way
    Sergeant:
  • 366 Answers
You need your XP installation CD.
Boot from XP CD.
Use admin password to run console.
Enter following command:
fixboot
fixmbr
cd
ren windows winvista
exit
When your PC restarts, boot onto your XP CD once again, and then proceed with setup normally to install your XP.
Detail here
Posted on Dec 28, 2008
  • Pat Batta
    Pat Batta Dec 28, 2008
    When you boot from XP installation CD you have several option offered.
    At suggested link you can see:
    "Start by booting to your XP
    disc: Just insert the disc into your drive and turn on your PC, then
    press the spacebar when it says Press any key to boot from CD... If you
    don't see this message, you'll have to enter your PC's BIOS setup
    screen and change the boot options so that your CD drive appears above
    your hard drive in the boot sequence list. Consult your PC's manual for
    details. (If you can't boot from your CD, you can download free XP
    Setup boot disk files by searching for Q310994 at
    support.microsoft.com.)
    When XP Setup starts, press R
    on the first page to open the Recovery Console. If you are asked to
    choose a Windows installation, type a number (usually 1) and press
    Enter.
    Recovery console is a powerful tool to manage your OS .
    When you have your system control under recovery console you can proceed renaming the file WINDOWS into new name (WINvista) to fool XP installer telling him no newer windows exists and you can proceed with XP installation.
    Check everything on provided link.
    Let me know if working OR if you have to apply to HP for (possible) roadblock removal
    Problem Solver:
  • 6 Answers
Are you getting a bluescreen, If you are then you need to contact your HP tech support and turn of the sata mode/ sata operations , or during installation of Windows Xp You Need to hit F6 and install sata drivers through a usb floppy drive... that is the only option... to get in to the bios to turn off Sata operations u need to hit " F10 " when u see the HP Logo When you turn the computer on...
Also please be specific about the error you are getting.. or how you are trying to downgrade....
Downgrade windows 7 to windows vista
Pl note that only Windows 7 Ultimate or Professional supports downgrade rights to Windows Vista Ultimate, Business or Windows XP Professional.
You can do a downgrade as long as you have a full version Windows Vista license.
If you are referring to Windows 7 downgrade rights, this option is specific to the manufacturer, computer model and the edition of Windows 7 you have installed.
Jul 18, 2012 | HP Computers & Internet
How can i downgrade my laptop hp pavilion dv4 to from vista to xp
The only way to downgrade is to backup all you files you want to keep, and then do a new install of XP.
Dec 20, 2010 | Computers & Internet
I have HP dv6701au laptop. previously it was loaded with Vista, but now i have installed XP. The problem is that i can't get the appropriate drivers for my laptop. i had already asked the same from HP...
Before downgrading from Windows Vista to Windows XP you should always confer with your computer's manufacturers website to look up your model and see if they support the downgrade. Often times the only way for you to downgrade is to have it done before receiving the computer, since a majority of the hardware on the laptop is made specifically for Vista and is not backwards compatible. Looking on the HP website, I see that they only offer a very limited number of Windows XP drivers for your system, which tells us that downgrading is not possible.
I would recommend that you consider not downgrading but rather upgrading to Windows 7 as it is a much more stable and functional OS than its predecessor Windows Vista. You can even run Windows 7 in Windows XP compatibility mode so you can enjoy the benefits and upgrade of Windows 7 but still have the Windows XP feel and functionality. I will be writing a How-To/Tip on Windows XP Compatibility mode today so you can be on the lookout for more information on that.
Jan 27, 2010 | Computers & Internet
Downgrading vista to xp
Now you need to find a Windows XP install disk that can match the licence number printed on the sticker at the back of the laptop and reinstall XP using your serial key.
You will have to download and install also the XP drivers, you find them on manufacturer website.
See links below on reinstalling XP on a Vista system:
FAQ: Giving up on Vista? Here's how to downgrade to XP
How to downgrade from Vista to XP News
How to Downgrade from Vista to XP
Downgrade Vista to XP pro
downgrading from vista to xp
Feb 18, 2009 | Microsoft Computers & Internet
Hi, I hold a Compaq c740tu notebooke PC with the pre installed windows vista. I face problems on running certain softwares and hence would like to downgrade to Windows XP. I managed to get almost all...
Yes do not downgrade or you Will have problems. Microsoft is planning to stop support for xp in the future and already have a new OS-7 coming out to replace vista. A lot of software that does not say it is for xp will work on vista. Just because it does not say for vista does not mean it will not work on vista. Good Luck. I love Xp too but I will not downgrade to go back because microsoft is only going to make it obsolete in the future.
please rate my thank You.
Jan 16, 2009 | Compaq Presario Notebook
I downgrade vista to xp my hp dv6835, dvr-k17b doesnt work
You need to download Windows XP driver from HP website and install on your laptop.
Nov 21, 2008 | Computers & Internet
Downgrade to xp from vista
plz check the drivers for xp for your model in manufacture website
Jul 21, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Where do I get the Downgrade to XP Pro
generally manufacture dont support downgrade, before downgrading please check for drivers for xp in manufacture website
Jun 24, 2008 | HP Pavilion dv6000z Notebook
Downgrading vista to windows xp
Yes, its possible to downgrade from vista to XP, you just need a installation CD of XP.
May 12, 2008 | Toshiba Satellite A105 Notebook
Downgrade
Hi, The XP drivers for your laptop are available at the HP site http://www.hp.com/. Click on "Software & Driver Downloads" leftside near the bottom, enter your product "Pavilion dv9205us", click on "Microsoft Windows XP". May I suggest that you download them now even if still running vista and then burn to a CD or copy to a flashdrive. That way when you have downgraded to XP, the drivers are readily available. Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | HP Pavilion dv9205us Notebook
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
