Question about HP Pavilion a1130n (PX769AA) PC Desktop
My hp wont get past loading screen.
When i got to boot menu it then selct last known configuration it says 'a file is missing or corrupt: \WINDOWS\system32\conifg\system.
    Sergeant:
  • 279 Answers
That's a registry error. SYSTEM one of the registry hive files. Click here for step by step instructions.
http://www.tweaksforgeeks.com/HIVEConsole/index.html
I hope this is helpful.
Posted on Dec 28, 2008
Hp site
Use Recovery Console
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
OR
Use Last known Good Configuration:
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
Jan 01, 2012 | HP Computers & Internet
I have hP mini 1000 that won't boot up windows. Just shows me Hal.dll error message. How do I fix that if it won't start.
you will need a copy of windows and an external disk drive then have it boot from the cd when it boots select install windows then leave the current drive intact with no changes or if the repair option comes up you can select that. do not select the repair at the first menu unless you are an expert in dos, always go to the install.
Jun 30, 2011 | HP Mini 1000 Netbook
Windows will not load can not get to desk top .notebook start files and or boot log is corrupt.system will not boot .windows 7 was just installed.
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 18, 2011 | HP Mini 1000 Netbook
My Compaq Presario wil not go past the windows xp screen and load up the programs?
Hit the F10 button on boot up you will get a choice there to boot last known good configuration.
This should work .. Something has altered your boot files
If this doesn not work ,Insert CD that came to you with Pc /laptop RESTORE CD.. this will add enough boot files to fix your issue
Then reboot with out the CD it will boot properly
if you do not have original CD borrow a cd from friend or someone boot from Operating system CD tis will restore your boot files
Jun 13, 2010 | HP Compaq Presario 2500LA Notebook
Acer travelmate 2410 comes on does not load past the acer screen
if last known good configuration wont work (go to advance boot option before it boots to windows, then choose last known good configuration), you must reinstall your operating system using the OS cd that came with the computer. it will wipe out all your files but it will restore your computer to factory default. that is if the hard drive hasn't failed yet. if so, if OS reinstallation still doesn't work, then you have to replace the whole hard drive.
Mar 29, 2010 | Acer Aspire One PC Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Windows wont start says file is missing or corrupt no disc drive to load cd rom, eeepc 1005ha
Try rebooting, tap F8 when splash screen appears ( just tap after the computer starts). When you see the multiboot menu come up, scroll down and choose "last Known Good Configuration". If this does not work, reboot and try "safe Mode", Run all your antivirus programs if you can.
Jan 15, 2010 | Computers & Internet
My emachine will not boot up
In the removal process, you may have removed the hal.dll file. The system configuration has changed and Windows is looking in the wrong place for it.
If Windows XP, use the XP installation CD. Change the boot order and boot from the CD.
First, try to restore the hal.dll file from the Windows XP CD. Boot your system without the CD.
If that doesn't work, use the Recovery Console which should fix the problem.
If not, more extensive work, such as Windows Repair or Clean Install would be necessary.
Hope that helps.
Jul 22, 2009 | E-Machines eMachines Desktop PC
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
Startup screen freezes
using the system restore disk, boot the laptop and choose repair, run chkdisk /r this repairs the system files, if this does not fix the problem, using the same system disk do a restore.
BPCS
Dec 06, 2007 | Dell Inspiron 8500 Notebook
HP Pavilion a1130n (PX769AA) PC Desktop Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
