Can't install CanoCraft CS-P 3.7 on new computer
I recently upgraded my computer but, when I re-install the scanner software for my CanoCraft CS-P 3.7 it tells me it can't detect a scanner and give me error 0x00070800. The scanner is plugged into the computer and switched on. I have tried installing and uninstalling several times. It previously worked on my last computer, which also had Windows XP, so I can't see why it won't work this time.
  • Anonymous Mar 28, 2009
    I had to get a new motherboard for my computer and then changed from win2000 to xp. because new motherboards dont have parallel ports I had to buy a usb cable to connect to my scanner (canocraft cs-p340). I installed the drivers from my original cd, but when I tried to use the scanner., I got the message "unable to detect scanners" Would appreciate some advice.
    Ronnie Hull ronhull@lantic.net
4 Suggested Answers
minicruzer
  • 7 Answers
SOURCE: Windows XP not recognising HP ScanJet 5370C
If its a new computer, but with the same software, don't you think it would be the computer's problem???
Posted on Jun 29, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: Is there a way to install Visioneer 4400 on Windows 7?
there are still no driver that can support the windows 7 for Visioneer 4400. No luck for that as of this time
Posted on Oct 31, 2009
SOURCE: No scanner detected. Error Code 0x00070800. Using Windows Xp!
Your scanner may not be compatible with windows xp. You may need to see if the manufacturer's website may have driver files for your scanner.
Posted on Sep 16, 2012
My PC run on Windows7, but I cannot install my CanoScan N640P, while many things I've to do.Soo please advise me.Thank you very much for your assistance. Regards, MLMenon
Hi. I hope this can still help. My PC runs on Windows 7 and my scanner is CanoScan N 640P ex 1. Enter your BIOS (hit "del" during start-up). Look for Port Settings and change it from ECP to BI-DIRECTIONALLY. Save & Exit. Turn Off PC. 2. While PC is off connect scanner parallel port wire 3. Go to: http://support-au.canon.com.au/contents/AU/EN/0900326001.html Download the software to your Desktop 4. Once downloaded the name of the file is SCCSP382WNEN. Right click on the icon (looks like a tiny microwave) and click Properties then click Compatibility tab then check Run this program in compatibility mode for (Choose Windows 2000) then click Change settings for all users. Again check Run this.. Apply & Save. Run this software and it will extract into a folder with same file name: SCCSP382WNEN. Open the folder and look for DISK1 folder, inside DISK1 folder right click on SET UP (size is 59 KB) and do the same thing: properties then compatibility, still windows 2000. Run Set-Up. After installation re-start computer. 5. Go to Start => All Programs = > CanoCraft CS-P 3.8 (right click on it) same thing: properties => compatibility (still select windows 2000) 6. Program will open and it will calibrate your scanner and will finally scan pictures and documents
Easy right? Windows, after all, still supports program that no longer have driver support for vista and 7
Good luck.
Nov 29, 2010 | Canon CanoScan N640P Flatbed Scanner
Scanwise cannot find the current colorsync system profile. I only recently upgraded to snow leopard and this was the problem message
Uninstall the scan software and install the snow leopard software not using the upgrade path. If the problem persist, install only the orignal scanner software.
Nov 15, 2010 | Agfa SnapScan E25 Flatbed Scanner
I can't find the driver/installer for my canocraft cs-p3.8? I need to install it to my pc but I lost the cd?
open google home page search driver magician
insatl update
all drivers
serch driver version size relaze dete
Oct 30, 2010 | Canon Computers & Internet
Canoscan Lide 20/lide30 Ver. 1.02 Will not load in my Mac 10.4.11 Tiger.Had it in my previous vergin mac 10.2 but since I've upgraded scanner tells me I've got error .06 and will not reload. I assume I...
http://www.usa.canon.com/consumer/controller;topic=609.msg7369?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=104&modelid=6624#DownloadDetailAct
Mac OS X (Native Mode)
  1. Turn the computer on. Log in as the first created administrator account to install the software. You cannot install the software when logged in using added administrator accounts.
  2. Place the CanoScan Setup Utility CD-ROM in the drive.
  3. Double-click the CD-ROM icon.
  4. Double-click the MacOS X folder/icon.
  5. Note: Some versions of the CanoScan Setup CD-ROM will not include the Mac OS X version of Toolbox. If this is the case, you should download and install Toolbox from Canon's website. www.canontechsupport.com
    If you will not be installing Toolbox at this time, skip to step 7.
    Double-click the CanoScan Toolbox folder/icon.
  6. Double-click the CanoScan Toolbox Installer icon. Follow the on-screen prompts to complete the installation.
  7. Once the installation of Toolbox is complete, you should then access the ScanGear CS folder also located in the MacOS X folder.
  8. From the ScanGear CS folder, click the ScanGear CS Installer icon. The installer will search for available install locations for the scanner plug-in driver. Follow the on-screen message prompts to complete the installation.
Jun 18, 2009 | Computers & Internet
Canoscan 9950F scanner will not scan with Win XP
Since you have had the scanner a while, you may not have a recent enough driver to work well with XP: until I smashed my 9950F, I was scanning under XP with the ScanGear CS 10.324a driver with no problems (the driver is dated 22 June 2007). You can download it from several sources on the web, I used
"http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=10446#DownloadDetailAct"
Other than that, they report some issues if the system drive is NTFS, but I was using NTFS for my system (and only) drive, so I don't see any reason for this to be your problem.
Good luck,
CWM
Mar 19, 2009 | Canon CanoScan 9950F Flatbed Scanner
Adobe photoshop CS 3 upgrade version
The point of an upgrade edition of a piece of software is so that you can upgrade your existing software. You need Photoshop 7 or higher to use the upgrade. If you don't have it, you will need to return/refund your purchase of the cs3 upgrade, and get the full version of the software instead.
Your other option is to purchase an earlier version of adobe photoshop, in order to install it so that you can upgrade it. Seems very round-about but I suppose it would work, and I'll bet if you find adobe photoshop 7 somewhere, it'll be awfully cheap ;)
Jan 28, 2008 | Adobe Photoshop CS2
Printer Port is used by another device
Just only check and delete error print task queue in all of printers.
Start->settings->printers and faxes.
Right click and open each printer on your machine to find which printer remain error queue and delete it.
Good luck...
sUPERTUYZ
Jun 18, 2006 | Canon CanoScan N340P Flatbed Scanner
463 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
