Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Laptop says excellent connection - not able to access internet
I have installed the linksys router successfully on the desk top. The laptop says that i have excellent connection but when i try to access the internet i have no connection. What am I doing wrong
    Sergeant:
  • 366 Answers
Connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Posted on Dec 28, 2008
Just moved to Canada and hooked my desk top up. i have internet through cable not phone line. i have internet with a cable from linksys to desk top but i have no wireless to laptops. i think i need to...
You need to configure the Linksys with the wireless settings, ie. the SSID and encryption. then you need to configure the wireless card in laptop with these router's wireless settings so it can connect with the wireless router.
Open a browser on your computer and type in the Linksys configuration URL.
http://192.168.1.1
The default login = admin
The default PW = admin
then go to the wireless section and configure the SSID and encryption. I suggest you use WPA or WPA2 these are much stronger encryption than the older WEP encrtption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
Connect laptop to my desktop.......monthly charge ?
no.. and chances you're not even doing what you describe.. she's likely simply accessing the internet through your linksys router, she probably does it wirelessly while your desktop may be wired to the router. the router is to share the internet connectivity so you're not going to be charge for having her connecting to the router. something you may want to keep in mind is that if you your stepdaughter did not require a key code /password to access internet anyone that is close enough to your house could to the same without your authorization. so configure some security on your router. your router's manual should let you know in details how to do it!
if you don't know where your manual is, post back with your model number and revision (at the bottom of the router) and we'll help out find the the manual.
good luck!!
Dec 27, 2009 | Linksys Wireless-G Broadband Router
Linksys rouder suddenly stoped alowing other computers net access
I would recommend upgrading the router firmware, if you have not done this already.
Download the firmware file from the Linksys website:
http://www.linksysbycisco.com/US/en/support/
Typically, the upgrade is done by pointing your web browser at the IP address of the Linksys router. Linksys should provide specific instructions at the site above.
Nov 01, 2009 | Linksys Wireless-G Broadband Router
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Linksys WRT54G wireless connection problems.
click on Start -> Control Panel -> Network Connections -> Wireless Network Connections -> Properties -> In the box in the middle scroll to and click on "Internet Protocol (TCP/IP)" -> Click Properties -> Make sure "Obtain an IP Address Automaticaly" is Ticked -> make sure "obtain dns address automatically" is Ticked. -> ok -> click ok
See if you can connect
Click on Start -> Run -> Type CMD and hit enter.
a command box will open. type in IPCONFIG/ALL
Please copy down the following numbers ---
IP Address
Subnet Mask
Default Gateway
DNS Servers
Please make sure you copy them correctly and post them here.
Dec 24, 2008 | Linksys Wireless-G Broadband Router
LINKSYSBYCISCO WIRELESS ROUTER
this is what is happening, please get me solution email is nickesdad51@yahoo.com
Dec 08, 2008 | Linksys WRT160N Wireless Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Cant connect to internet from laptop
The network key is stored in the router, and your manual will tell you how to access it.
If you don't have access to the router's web page, you'll need to reset the router and start over.
Dec 20, 2007 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
168 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
