Question about HP Photosmart C7280 Laser Printer
Whats up with fax fail test
Your printer says an active phone line was not detected when one is there called comcast they said compatible any ideas?
  • Anonymous Mar 17, 2009
    HP C7280 does not recognize Comcast digital phone line
    Master:
  • 461 Answers
Check to see if your phone operates on the same jack the printer is connected to. Is comcast your telephone service or internet provider? You need to have a landline phone service or VOIP for a fax to work.
Posted on Dec 28, 2008
I can't transfer my home phone number
where do you want to transfer it to ? normally i would call my service provider either comcast or att and they can change my address on the home phone line and can be done. you will have to call them and ask them to send an agent to activate the line at your new place.
Aug 21, 2013 | Computers & Internet
I have a hp officejet all-in-one and I can't get the fax function to work. I have comcast digital voice with a rca modem. The fax machine dials and the line goes dead. If I call the fax number on the...
Since you have a DSL ( Digital Subscribers Line ), the HP Fax printer works on Analogue Signals.
To make the GP Printer work on Digital line, First step you can do is to Reduce the Fax Speed from Fast/Medium to SLOW.
To Do so, Click on Setup button on printer front panel - Choose Fax Settings - Choose Fax Speed - Set it to Slow and try to fax
If this does not work, you will have to connect a DSL Filter ( this is a 2 way port - 1 port for Digital line and another for Analogue )
You will have to connect this Filter to DSL Phone line - in the IN port and from the Analugoue Port - Connect Phone cable to Printer Line 1 EXTN Port at back of Printer
Jul 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Will not send a fax
There is two things i can think of that can cause this. The number one is if you are using a voip carrier (like vonage or att voip or comcast digital voice) they are usually not compatable with fax machines. You will need either a dedicated fax line or you will need to whats called a fax line from vonage or comcast, or from your voip service. If you are using a phone line test to make sure you have it connected correctly buy simply dialing your cell phone or a friends cell phone (let him know you are going to test) once you do this you will hear a ring and an annoying fax machine tone buzzing in your ear. if this is the case and you do have everthing connected correcly i would put a trouble ticket in with your phone company, to test the line condition of your line (to make sure its not shorting or anything like that)
i hope this helps if there was more information i could do better but hopefully this will help out a bit.
Thanks
Steven
Apr 29, 2010 | HP PSC 2210 All-In-One InkJet Printer
I can not send or recieve faxes. Ran fax test
Cox Cable is pretty much the same as comcast's and vonage's services. HP fax machines have had HUGE compatibility issues with those types of services, and may be that they did something to their service that caused your fax to stop working.....
Other than that call HP and see if they have any troubleshooting or Diagnostics that you can run, but I ran in to these problems with HP faxes all the time while installing comcast phone service, never knew WHY it didn't work, just that HP doesn't work on that type of service.....at least certain models...Also maybe call COX and see if they did anything recently that could cause it to stop working....
Jun 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Dell fax machine will not recognize incoming fax call on comcast cable telephone line
Direct from COMCAST FAQ:
Do fax machines work with Comcast Digital Voice service? Yes. However, there may be some equipment brands or models that are incompatible with Comcast Digital Voice® service. Click here to review a list of equipment that has been known to have compatibility issues with Comcast Digital Voice service.
Jan 15, 2009 | Dell 1600n All-In-One Laser Printer
Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Jul 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Faxing errors on comcast digital voice
I am afraid to inform you that Comcast does not support faxing.
Please click on the web link given below to get the answer.
http://www.comcast.com/customers/faq/FaqDetails.ashx?ID=2189
Have a great day!
Feb 09, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Sending faxes
I believe if you have comcast it is a different signal coming in, you probably bought the package for VOIP capability when Comcast was having that promotion. The phone has to be a regular analog phone line not digital, that is probably your problem. Try changing the settings or line it should solve your problem, or call Comcast to guide you along. Cheers!!
Mar 02, 2007 | Lexmark OfficeCenter X3350 All-in-One...
HP Photosmart C7280 Laser Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
