Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
The 2" panel between the doors on my whirlpool refrig are extremely hot...Help
  • djl106 Dec 28, 2008
    The 2" panel between the doors in my fridge is also extremely hot, so hot there is a smell of burning rubber. the fan is working but it is hard to clean the coils underneath. my husband is trying to clean it with air.
    thanks
  • TNJC Dec 29, 2008
    I have the same issue.  Very hot to the touch.  Ice maker does have water in the tray and has quit working as well.
  • 115 Answers
It is suppose to be warm but you want to check you condensor fan in the back on bottom if it is running then clean your coils underneath with a brush or maybe air
Posted on Dec 28, 2008
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
The strip between the freezer and refrig door is extremely hot. Never felt hot before. It is not the door, but the refrig and freezer itself. The refrig is still cold and freezer is frozen.
The heat you are feeling is normal, I wouldn't worry too much about it. If you start having a problem with cooling you may want to look into getting a repair guy to look at it but many refrigerators will heat up in that strip between the fridge and freezer.
Dec 12, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
I have a 6th sense whirlpool 25.6 cu with water
First , remove the kick plate and make sure the coils are clean of dust . lint , pet hair , etc . Then pull the refrig out and remove the rear lower panel , covering the compressor and cooling fan ( evaporator motor ) . Make sure this motor is working , if the compressor is running . If the fan does not work , then replace it as soon as possible . This fan , cools the coils and the compressor , which if not working , causes the divider strip to become extremely hot , and could cause the compressor to have problems , due to the heat . After removing the rear panel , be sure to re-install it , as this is there , to direct the air flow as needed .
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Molding around door is hot
The fan which cools the compressor , needs to be replaced or checked for fan blade obstruction . Pull the refrig out and remove the lower panel , covering the compressor and fan . Check to see if something has caught in the fan blade . If not and the fan is not working , replace the motor . ALSO , check the coils in the bottom front of the refrig , to make sure they are clean of dust , lint , pet hair , etc .
Oct 15, 2009 | Whirlpool Refrigerators
Refrigerator gets extra hot on top and side
The only thing that I can think of that would cause this is heat strips that are placed around the door frames to prevent moisture from forming around the doors. The way you have explain what is happening is an indication that the strips are out of control. If you can find the model number located on the bottom of the fresh food compartment door frame behind door get that for me. The problem is unsafe and should have your full attention until resolved. The parts cannot be replaced and can short out. If you have a local dealer or someone to talk to about the problem would be a good
idea. If you can find model number let me know. The model number above your post appears to be incorrect. Thank You Sea Breeze
May 24, 2009 | Whirlpool GD2SHGX Refrigerator
Tryng to buy stainless steel door panel for KitchenAid KBRP20ERSS
you can call you whirlpool direct, (number is inside refrig/owners guide.)or local part warehouse, heres the part numbers,prhaps you can find a supplier online
8208307--refrig door panel
8208308-- freezer door panel
Jan 11, 2009 | KitchenAid KBRP20ERSS Stainless Steel
Extremely hot panel between freezer and refrig sections
Usually is not a fire danger however there is a problem that needs attention. I would recommend that you call a qualified service man for this one as soon as possible.
Nov 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
