Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
PT-53TW53 My audio is fine ,but the picture is just the three colors as a wavy line down the very center of the screen. Top to bottm. Help me, please
Try to read this blog: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Apr 30, 2007
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
There is wavy lines in the screen i got most of them out but not all
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Apr 22, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Just tonight we were watching TV and the screen got darker. Picture is still fine, just got darker, on some channels the top and bottom center bow in toward the center a little, easy fix or a lot of...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Panasonic PT-51G53 51" Rear Projection...
My bottom part of tv to the left side became a little wavy and it's showing double and you can see also letteing in red color.
*Screen Looks 3-D
*Colors wont align
Nov 07, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
There are green wavy lines that follow the outlines of most
*Screen Looks 3-D
*Colors wont align
Apr 30, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Fuzzy picture
never adjust the tubes themselves( No-NO) these are affixed to the chasis in one position and not to be moved. no adjustments should ever be attempted to anything directly attached to the tubes. this will throw off centering, soft-focus, & convergence alignments. it can be corrected but a huge burr on the bottom of the foot! what you have are faulty convergence ic's and maybe sme low-ohm resistors that are bad. repair in-home should not exceed 350.00. parts and labor. mch
Mar 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
3 green spots on the top center of my projection hd tv
I had a similar problem and brought it in to a technician for a quote of $860 to fix. The problem - speck of dust on the optics. If it weren't under warranty I would take it apart and blow off the dust myself.
Dec 19, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G
Mikey,
There are any number of possible failures that can cause the symptoms you're describing. For example, C509 a .47uf/250v mylar cap has been known to fail in those units causing the wavy lines. On the other hand convergence amp failures can do the same thing. That unit uses two STK392-110 Sanyo amps at pos# Ic7001,Ic7002 Panasonic p/n# C5aa00000203 and more in that circuit needs to be tested and signal traced to isolate all of the problem if the amps are the culprit. In short, I don't think this is one you want to tackle with less than a 20 mhz scope and some serious background in electronics.
Bill
Dec 11, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
