This is the story my wife gave me. Sequence of events. Got into vehicle and shifted into reverse and rolled the passenger and driver window down at the same time without car being fully started. When she realized the car was not moving she put it back into park and started the car up shifted into reverse and drove off. As she approached the highway on ramp she flipped the switch to raise the windows and they did not go up nor where the power locks working. The weird thing is when you shift the car in reverse the locks work and when you shift into park they unlock. I checked the fuses and they are okay. I disconnected the battery in the hope this would reset something she may have inadvertently done with no luck. Anyone have any suggestions as to what might have gone wrong? Your help is greatly appreciated. Thanks
The power windows an power locks are controlled by a module , DDM - driver door module . As far as the locks locking when you put the vehicle into reverse an unlocking when you put the vehicle into park , that's how there are suppose to work , automatic lock an unlock feature . When you put the vehicle into any gear from park the locks should lock . Did she hit window lockout function ?
The power door lock system consists of the following components:
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Driver, Passenger and Cargo Door Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
• The DDM (driver door lock actuator).
• The PDM (passenger front door lock actuator).
• The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
SOURCE: 2004 tahoe
make sure than you have not split any fluids on the passenger front door most of the times is where the module to control the windows and doors is located, try by unpluging the batterie and the after a minute plug it back and see what happend but if any of your ft doors have been split with liquid or rain has gone inside then most likelly the module got moisture and not working
SOURCE: power windows
As long as the windows will work fine some of the time, it sounds like the problem is in the power supply and replacing the fuse should fix it, otherwise there may be a loose wire somewhere in the circuitry.
SOURCE: 2002 expedition-locks in park after starting,windows not working
You just need to change a fuse.
SOURCE: Power windows not working
Sounds like a bad master switch, bad wiring to the drivers door, or bad body control module.
