Question about Jensen VM9510 Car DVD Player
Sd card reader, jensenvm9511ts
I'm trying to get the sd reader to pick up my mpeg4 formated vidoe files, can't seem to get it to work, picks up mpeg3 audio files. any ideas?
    Novelist:
    Scholar:
  • 84 Answers
All I have to offer you is to verify the mpeg4 format using GSpot software which can be found here: http://gspot.en.softonic.com/ Also, the max supported SD Card size for your unit is 2GB. I'm sorry I couldn't be of more help.
Posted on Aug 01, 2007
Sd card recover deleated vidoes pic and more
Do you want to recover deleted videos and pictures from a SD card?
Why don't you try 4Card Recovery. It is able to recover all kinds of files.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Mar 10, 2014 | SanDisk Sansa e250 MP3 Player
My micro SD format first the disply every time in the time of connecting to pc
Different systems do not all use the same format, so its possible that your card is formatted for a Linux system (perhaps your phone) and windows is trying to format the tiny amount of free space left over.
I would recommend trying a different card reader (your local library should have one you can try) or a friend/university to see if you can read the card at all.
If the card is fine then you might have better luck with a different card reader, you can pick up a multi card reader in the UK for max £15 should be much cheaper if you get a device specific for micro SD.
It would also be worth trying in an apple mac as they can read most file systems, unlike windows.
Also check if it has a "lock" a physical switch on the card which should indicate which direction is locked and which is not. Its unlikely that a micro SD card has one as by virtue they are supposed to be small.
Good Luck!
May 04, 2011 | Computers & Internet
SD Card is inserted, but message reads "SD Card blank or has unsupported file system". Can I do anything to remedy this?
Hi jerilee436,
Let's start with easiest thing first... Take out your SD card and re-insert it and see if your phone picks it up. (If you don't already know this is how you locate the SD card: http://www.fixya.com/support/t8475945-g1_memory_card_slot)
If that doesn't work, you can try putting your SD card into a card reader (You may already have one on your computer. However, if you don't ask try asking a friend if they have one OR you can purchase one from here: http://www.amazon.com/Sandisk-MobileMate-Plus-Memory-Reader/dp/B000Q3IUV2). If the card works in your computer try formatting it and putting it back into your phone. Still doesn't work? Try a different SD card in the phone. If that ALSO doesn't work then you likely have a bad card reader in your phone :'( You'll have to call up your cell phone provider and see what they can do from there.
Hope that helps!
Feb 01, 2011 | HTC G1
How to format sd micro card FAT 32 system vista home premium thank you philip
- Make sure the SD card is detected
- Go to my Computer
- Right click the SD Micro card -> pick Format
- Select FAT 32 from File System
Oct 26, 2010 | Computers & Internet
Unable to read 2gb micro sd card
mmc cards are notorious for faults and compatibilty issues ,
for instance some cameras only use sd cards and will not pick up none sd cards . if you have an mmc reader which connects to your comp/laptop you can see if that picks up the card .
some times all is need is a format other time you need to check compatability and that is not physically faulty
Aug 02, 2010 | PNY 2GB microSD Memory Card
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Micro sd card mp4 video says " playback error"
Sometimes the downlodad file format wont support the the file fornat of the phone .If u are using the micro sd card fo the first time the format the card . otherwise it may have this problem.
Jul 06, 2009 | LG Xenon GR500 Cell Phone
Problem transferring pictures to PC
do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
Mar 28, 2009 | Pentax Optio A10 Digital Camera
Acer 5920 does not work with sandisc 1gb memory card
Your Minolta camera uses file format, which is not recognized by PC and vice verse. When you insert, PC can't read it, and asks to format. But when it is formatted for PC, your camera can't read it. Try to format it in camera, if it's not possible, then get a new memory card and use USB cable to copy images.
Feb 15, 2009 | Acer (AST135-U-S3100) PC Desktop
Jensen VM9510 Car DVD Player Logo
147 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
