Question about Toshiba Satellite A215-S7422 Notebook
Laptop wont turn on at all/ satellite A215-S7422 pc notebook
THE PROBLEM I AM HAVING NOW IS THAT IT WONT TURN ON AT ALL AND THE DVD IS STILL IN THE DRIVE?
  • Toshiba Master
  • 32,281 Answers
On all CD and DVD drives there is a small hole on the front
CD/DVD panel. Straighten a paper clip and insert it into this hole and the tray will pop out, you will then be able to remove the DVD disk.
If your laptop does not turn on, even when the power adapter is connected to the main, and there are no lights on to indicate it is connected to the mains and charging, then you could have a faulty adapter which means it could not charge the battery and the battery is flat.
Test the adapter with a multimeter to see if it is OK or borrow an adapter (make sure it is the same type and voltage) as your adapter and connect it to your laptop. If it works the you need to buy a new adapter. You can also test your adapter on a different laptop to determine if your adapter is functioning.
If there lights on when you connect the adapter to the mains, and your laptop does not boot up or run the POST (power on start test), you could have faulty RAM (memory) or the RAM is not making proper electrical connection.
Reseat your RAM several times and then boot up your laptop, if it still does not work then you possibly have faulty RAM. Remove your RAM and swap it into a working laptop to check if it is faulty (you may be able to get your friendly computer shop to check it for you). If it is faulty then you need to purchase new RAM.
Posted on Dec 28, 2008
    Novelist:
  • 101 Answers
If you are trying to retrieve the DVD from inside a laptop that won't turn on, the easiest solution is ... a Paper Clip! Straighten one end of the paper clip and insert it into the small hole on the face of the DVD drive and the door will open.
Activating crisis mode for toshiba satellite a215-s7422
If you mean safe mode, as soon as you turn on the computer start pressing the F8 button about once a second. That should bring you to the safe mode option.
Jan 04, 2010 | Toshiba Satellite A215-S4747 Notebook
Paseword
Can't be changed on a notebook, this is a security feature to prevent someone stealing your notebook and using it. You'll have to send it to toshiba or a shop that can change it.
Jul 05, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba satellite a215-s7422 fan not running can i replace fan? how?
Replacing your fan will void your warranty.
I would advise talking to toshiba for a replacement.
If still you want to replace ir, you have to disassemble the whole laptop to replace the fan, all you have to do once disassembled is unplug the original one and plug the replacement one, but you have to use only compatible ones, or else you will burn your cpu or the fan wont fit.
For a quick resolution, buy a powerfol laptop cooler.
Cheers
Jun 21, 2009 | Toshiba Satellite A215-S7422 Notebook
Forgot password for toshiba satellite A215-S7422
If it is a bios password your computer may be known for this issue. You could try calling Toshiba support @ 1-800-457-7777
Mar 20, 2009 | Toshiba Satellite A215-S7422 Notebook
Will not power up
most likely the fan has gone bad or the vent slots are all clogged up with dust. get a can off dust off and blow out the vents.
Feb 26, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba satellite notebook won't turn on
You might have a virus or the movie or dvd player might be corrupted, if it continues to happen go to a computer shop to get your dvd drive checked out.
it could be : SOFTWARE- DVD PROGAM,
HARDWARE- DVD DRIVE or just a once in a lifetime error.
Please contact me if you need further assistance
Dec 26, 2008 | Toshiba Satellite A215-S7422 Notebook
Bluescreen
You can do the sytem recovery by loading the first disk then turn your NB off. Please hold down F12 after power on then select CD/DVD drive then Windows will be loading files. Select the first options for each prompt. You will be asked for the second disk later. Plug in ac adapter since it will take around an hour. Hope this helps.
Oct 19, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
