No sound output
I have an Optimus LAB-1100 turntable with a built in pre-amp, connected to the line-in socket of my PC. My sound card uses C-Media Wave drivers and I have been using Polderbits sound recording and editing software to digitize my old LP music. It has worked fine for quite a while (and I am really impressed with Polderbits and their customer service), but suddenly I am not getting any sound input to the PC.
I can hear the music faintly from the stylus, so does this mean that the pre-amp is faulty, or have I messed up the settings in the Audio control?
  • richardwarla Dec 29, 2008
    Problem solved! I had downloaded a new driver for the C-Media chip and used the default option when asked to select the input/output plug configuration. Default option was the wrong one for my PC!
  • 5 Answers
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Posted on Sep 18, 2008
SOURCE: How to remove platter on Optimus Lab-1100 Turntable
on the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
Posted on Oct 26, 2008
  • 104 Answers
SOURCE: optimus lab 1100 truntable will not operate.
this is a belt driven platter. the belt is old and fell off. http://www.archive.org/details/Turntable_Belt_Installation
this link shows how to replace a belt, once you see where the belt goes thread a piece of string through the mechanism where the belt should go and measure it and contact them with the length. or measure total length of the old belt if still in one piece. figure about $14 for most belts.
Posted on Feb 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Posted on Apr 24, 2009
jomabug76
  • 1148 Answers
SOURCE: Is there a belt diagram for Optimus LAB-460
try radio shack website,,or optimus site,,,for it,,should have manual
Posted on Nov 03, 2010
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
How to connect sony dav-hdx 900 to turntable
If the Sony has a dedicated "phono" or record deck socket, you should use that. Many modern amps however don't. In which case use a tape in socket or aux one. You will also need in-between the two devices a Magnetic Cartridge Pre-amp. These can be found by searching the internet. Without this device the sound will be very low. Amps with dedicated sockets normally have the pre-amp built in. Consult your user manual to see if it does have one built in.
Aug 23, 2014 | Audio Players & Recorders
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
How do I replace needle on Optimus Lab 1100
The manual for the Optimus LAB-1100 can be found here: http://support.radioshack.com/support_audio/doc63/63393.pdf
Replacing the needle is on page 13. I did it and it was easy.
Cheers, Gordon.
Dec 18, 2012 | Audio Players & Recorders
Distorted sounds
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
May 09, 2009 | Audio Technica AT-PL120 Turntable
No output to speakers from line-in port
Usually record turntables are not amplified at all.
Also make sure you are using Line In (stereo) and not Mic In (Mono). And be sure the cable from the record player (turntable) is stereo also.
Check your audio settings in your pc software and make sure the Line In is not muted and is at the correct level for you to hear it. Some sound cards also allow the Line In to be Line level or Pre-Amped the signal from the turntable may need to be boosted. Let me know if this solves you problem or maybe I can help further.
Please help me continue to help you with a good rating when it is deserved. Thanx, - CompuWayne
Dec 29, 2008 | ASUS Xonar DX Sound Card
Replacing needle
Cheers, Gordon.
Nov 24, 2008 | Audio Players & Recorders
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
62 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
