Mitsubishi WS-55807 TV Logo
Posted on Sep 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green light is on but no picture visible, black screen
ernesto cuadra
Level 3:
Top Expert:
  • Mitsubishi Master 12,223 Answers
  • Posted on Sep 25, 2012
ernesto cuadra
Mitsubishi Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4077916
Points
34431
Lack of raster : test the power supply b) horizontal output c) output transistor d) HV rectifier e) Flyback.
God bless you
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Samsung Plasma ps-42s5h has two black lines running vertical with green strip in the middle
Ok we have to resolve the extent of the problem before diagnosing it. Does the black line/green bar show on all inputs and the tuner? Is it visible in the OSD (on screen display)? if yes to all of these questions, it could be a panel drive problem or a bad plasma panel. A picture would help diagnosis
1helpful
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Spetroniq 42"lcd screens black no picture no
Sounds like maybe power supply, but I would check with flashlight 2 in from screen when the green light comes on to see if you have a picture, if so then you have a bad inverter board, if not then power supply problems. You can look for bad or bulged caps in PS
3helpful
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
1helpful
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
2helpful
2answers
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
