Question about Toshiba Satellite A105 Notebook
Multimedia pad The multimedia keys do not work after change the wireless adapter.
    Guru:
  • 829 Answers
I suppose you need to re-install the multimedia key drivers which you should download from the below link .
Chipset drivers for audio, video......
http://www.csd.toshiba.com/cgi-bin/tais/...
Atheros driver....
These drivers are for XP, if you have Vista please update the question or email me.
Posted on Dec 28, 2008
Comcast changed my wireless password and now my netgear extender doe not work
You will need to reconfigure your extender, check the manual or online at the link bellow.
Since your extender is not working your range is diminished.
WiFi Range Extenders
Oct 18, 2015 | NetGear Universal WiFi Range Extender...
Have a bunker hill safe. battery died. lost instructions but have the key. how do i find my way into to change
Remove the sticker on the front panel with the SKU number, behind it will be a small hole, use a small screwdriver to remove the screw, then carefully remove the number pad. You will see the place to use your key.
Nov 01, 2010 | Check Point Network Adapter
I have a dell 1180 truemobile USB wireless adapter and does not sem to coneect to my AT&T U verse. has WEP key enter and U verse has a WPA key. are these incompatible? How can I make it work
if the adapter wont do WPA then yes it is incompatible. You will have to logon to your modem/router and change its wireless settings to WEP
please give details of your router/modem etc if you need help with this
Jan 15, 2010 | Dell TrueMobile 1180 802.11b Wireless...
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
NEED HELP W OPENING MY BUNKER HILL SAFE
give harbout freight technical support a call at 1-800-444-3353
Give them the model number of the safe and the key code that is etched on the front of the key slot.
If you cannot find the key slot, it is hidden behind a plastic panel, located right next to the key pad.
They will charge about $2.00 per key (that cost may have changed)
and it will take about 6-8 weeks to get it.
robert
Sep 08, 2009 | Check Point Network Adapter
Changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
Jul 24, 2009 | Chamberlain 950CB Remote Control
Wireless mouse is not working. computer says the wireless button is turned off. can't find it to turn it back on. hp dv6 1030us
Check your bios settings when the computer first turns on it well say press F2 to enter setup (could be a different F key) if it doesn't say that, try pressing F2, F1, F10, and F12 or the DEL key. if these don't work, Try again and press all the Fkeys across the keyboard. on will take yo into setup and you should find a wireless device setting to turn it on. If you can't find one, you may not have a wireless adapter installed in your system.
Jul 13, 2009 | HP Pavilion dv6-1030us Notebook
Ethernet driver needed
drivers are here
and thanks for the product key, only joking, that should be kept to yourself
Jun 18, 2008 | Belkin (F5D7010) 802.11a, 802.11g/b...
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Changed router to airport extreme - no connection
bayoubill:
I am sure that Airports are WPA compatible. You manually put in the key of WPA or WPA2 in the router itself (in your case since you changed the router so please put in the key onto your aiport) make sure that this key matches the key onto the clients workstations or laptops.
Let me know.
Thanks
Dec 20, 2007 | D-Link AirPlus G DWL-G510 802.11g/b...
Toshiba Satellite A105 Notebook Logo
477 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
