Question about LG DLG5932W Gas Dryer
LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
I HAVE BLINKING CHECK THE FILTER LIGHT. DRYER BLOWS COLD. TRYING TO SEE IF THERE IS SOMETHING I CAN RESET, OR CHECK THE HEATING ELEMENT. BUT CAN'T GET DRYER APART!!! I have a gas LG dryer model DLE2532W that will not ignite the burner. The solenoid does not open. Does this igniter have to glow before the solenoid opens the gas valve? Thank you
  • 1947elk Dec 29, 2008
    Thank you for letting me know about the high limit reset. My vent was froze shut. Thank You Greatly!!
  • xassper8ing Jan 10, 2009
    We have tried the reset switch it is still not working. Ant suggestions.
  • 1,543 Answers
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
I have an LG DLE2532W and the check filter light keeps blinking even though it is clean and the dryer won't work what could be wrong?
There is a thermostat or safety somewhere on the dryer where the filter is and it probably is dirty or bad.
Mar 13, 2011 | Dryers
Loud humming sound while drying, need instructions on disassembly to properly diagnose
Disconnect power to dryer. Open door, remove phillips screw from 4 and 8 O'Clock positions, close door. Use putty knife (preferably a plastic one to prevent scratching) to push in the two clips holding the top to the front panel, then swing the top back, revealing the phillips screws holding the front panel onto the body of the dryer. Remove them and un-hook door switch and drum light connections, allowing total removal of dryer front panel. Remove 4 phillips head screws retaining front drum support and lift it up just a bit to remove it. Reach back under drum to the left side to release belt, allowing drum to come out of dryer.
Jan 29, 2010 | LG DLE2532W Electric Dryer
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
Doesnt heat blows cold air
well the first thing that should be checked is resetable thermostat..onthejob
Jan 17, 2009 | LG DLE2532W Electric Dryer
LG Dryer DLE5977B is putting out hot air,but clothes not drying. Check filter light is blinking. Nothing in lint filter. Checked entire vent system all the way outside. Nothing is obstructing it. ...
Go to www.repairclinic.com and enter DLE5977B. With luck, you will be presented with a list of common replacement parts and may be able to view a generic LG video showing disassembly. From this information, you may be able to pinpoint the cause of lint backup into your dryer.
Dec 19, 2017 | LG Dryers
DLE2532W Dryer
I had the same problem. Really glad I came to this site. Had already tried to clean out the filter area. What really worked was unplugging and resetting the computer. Everything seem fine now.
Mar 16, 2008 | LG DLE2532W Electric Dryer
LG DLG5932W Gas Dryer Logo
1,030 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
