Question about Great Plains Industries Gpi& Fuel Pump
Pump - Great Plains Industries Gpi& Fuel Pump
  • 15,935 Answers
Yes
Posted on Dec 28, 2008
Do you have to drop the engine to replace oil pump in 2007 gmc yukon
You have to remove the engine front cover (over timing chain) and remove the oil pan to get the oil pump in and out. You don't have to remove the heads, however.
Removal & Installation
4.8L, 5.3L, 6.0L & 6.2L Engines
Fig. Exploded view of the oil pump mounting-4.8L, 5.3L, 6.0L and 6.2L engines
Fig. Oil pump disassembly-4.8L, 5.3L, 6.0L and 6.2L engines
  1. Remove or disconnect the following:
    NOTE
    Do not allow dirt or debris to enter the oil pump assembly, cap ends as necessary.
    NOTE
    The internal parts of the oil pump assembly are not serviced separately (excluding the spring). If the oil pump components are worn or damaged, replace the oil pump as an assembly. Do not attempt to repair the wire mesh portion of the pump and screen assembly.
    Engine front cover Oil pan Oil pump screen bolt and nuts Oil pump screen with O-ring seal. O-ring seal from the pump screen. Discard the O-ring seal. Remaining crankshaft oil deflector nuts. Crankshaft oil deflector Oil pump bolts
    Oil pump To install:
    NOTE
    Inspect the oil pump and engine block oil gallery passages. These surfaces must be clear and free of debris or restrictions.
    1. Align the splined surfaces of the crankshaft sprocket and the oil pump drive gear and install the oil pump. Install the oil pump onto the crankshaft sprocket until the pump housing contacts the face of the engine block.
    2. Install or connect the following:
      NOTE
      Lubricate a NEW oil pump screen O-ring seal with clean engine oil.
      NOTE
      Push the oil pump screen tube completely into the oil pump prior to tightening the bolt. Do not allow the bolt to pull the tube into the pump.
      Oil pump bolts. Tighten the oil pump bolts to 18 ft. lbs. (25 Nm). Crankshaft oil deflector
      NEW O-ring seal onto the oil pump screen
    3. Align the oil pump screen mounting brackets with the correct crankshaft bearing cap studs.
    4. Install or connect the following:
      Oil pump screen Oil pump screen bolt and the deflector nuts. Tighten the bolt to 106 inch lbs. (12 Nm) and the nuts to 18 ft. lbs. (25 Nm). Oil pan Engine front cover
Mar 06, 2015 | GMC Cars & Trucks
Pump says pump not connected
turn off everything then control on then pump
Jan 26, 2014 | Zodiac Pool Systems Jandy ePump Variable...
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
Water pump
Which engine?
  1. Drain the radiator
91192665
  1. Loosen the water pump pulley bolts.
  2. Remove the serpentine belt.
91192666
  1. Remove the water pump pulley bolts and pulley.
  2. Remove the water pump bolts, pump and gasket.
  3. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump.
91192667
  1. Install the water pump bolts. Tighten the water pump bolts to 89 inch lbs.
91192668
  • Install the water pump pulley and bolt until snug.
  • Install the serpentine belt.
  • Tighten the water pump pulley bolts. Tighten the water pump pulley bolts to 18 ft. lbs.
  • Fill the cooling system and purge of air.
  • Inspect for leaks.
  • Sep 27, 2012 | 2001 Oldsmobile Alero
    How to tighten a water pump on a 1990 oldsmobile 88 royale
    For water pump replacement i suggest you to check the help link provided below.
    click the link below :----
    Water pump replacing procedure for all vehicles?
    http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
    HOW TO REPLACE A WATER PUMP
    http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
    How to route Water Pump Belt for 1992 Oldsmobile ?
    http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
    How to replace Water Pump on Car ?
    http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
    How to Remove Water Pump?
    http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
    Where is Water Pump located ?
    http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
    This will help. Thanks.
    Feb 14, 2012 | 1990 Oldsmobile Eighty Eight
    How to replace water pump infiniti m35 2006
    Feb 12, 2012 | 2006 Infiniti M35
    Change the water pump
    • Tools Required
    • J 43651 Water Pump Holding Tool
    • Remove the thermostat housing.
    • Remove the water pump access plate from the front cover.
    • Remove the right hand fender liner.
      1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
      Drain the coolant from the water pump using the plug at the bottom of the pump.
      1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
      Install the J 43651 into position.
      1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
      2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
      3. Remove the 3 inner water pump sprocket to water pump blots.
        1. Important: Be sure to remove both water pump bolts from the front of the engine block.
        Remove the 2 water pump bolts.
        Remove the rear 2 water pump bolts.
        1. Remove the water pump.
        2. Remove and discard the water pump O-ring seal.
        1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
        Install a NEW water pump O-ring seal.
        1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
        Using the guide pin, align the pin with the water pump holding tool.
        1. Position the water pump against the engine block and hand tighten the water pump bolts.
        2. Notice: Refer to Fastener Notice.
        Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
        Tighten the bolts to 25 Nm (18 ft. lbs.).
        1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
        2. Remove the J 43651.
        3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
        4. Install the right hand fender liner.
        5. Install the thermostat housing.
    Aug 29, 2011 | 2006 Pontiac Solstice
    How long does it take to replace a water pump on Pontiac Aztec?
    It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
    Removal Procedure :
    1. Drain the cooling system until the coolant is below the level of the water pump.
    2. Remove the drive belt guard.
    3. Loosen the water pump pulley bolts.
    4. Remove the drive belt.
    1. Remove the water pump pulley bolts.
    2. Remove the water pump pulley.
    1. Remove the water pump bolts.
    2. Remove the water pump.
    3. Remove the water pump gasket.
    4. Clean the water pump mating surfaces
    1. Install the water pump gasket.
    2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
    3. Install the water pump bolts.
      • Tighten the bolts to 10 Nm (89 inch lbs.) .
    1. Install the water pump pulley. Loosely install the mounting bolts.
    2. Install the drive belt.
    3. Install the water pump pulley bolts.
      • Tighten the bolts to 25 Nm (18 inch lbs.) .
    1. Install the drive belt guard.
    2. Fill the cooling system.
    3. Inspect the cooling system for leaks.
    4. That's it.
    Nov 18, 2010 | 2001 Pontiac Aztek
    Water pump replace
    Water Pump Replacement (3.8L)
    Removal Procedure
    1. Drain the cooling system.
    2. Loosen the water pump pulley bolts.
    3. Remove the drive belt.
      3. Remove the power steering pump and reposition.
      4. Remove the water pump bolts.
        2. Remove the water pump gasket.
        3. Clean and inspect the water pump mating surfaces.
          1. Notice: Refer to Fastener Notice in Service Precautions. Install the water pump bolts.
            • Tighten the long water pump bolts to 34 Nm (25 ft. lbs.) .
            • Tighten the short water pump bolts to 22 Nm (16 ft. lbs.) .
              2. Install the water pump pulley bolts.
                • Tighten the bolts to 13 Nm (115 inch lbs.) .
              1. Install the power steering pump.
              3. Fill the cooling system.
      5. The Whole Thing I Know You Didnt Want to hear that about The P/S Pump Thats why I Did More Reserch you seemed to Know what You are Doin They get the Best of us though Hope this Helps & RATE ME PLEASE
    Feb 03, 2009 | 2005 Chevrolet Impala
    Great Plains Industries Gpi& Fuel Pump  Logo
    Top Great Plains Industries Garden Experts
    GMfixins
    Thomas Perkins
    Thomas Perkins
    Mai Lor
    Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
