Question about Maytag PAV2300 Top Load Washer
Washer Will Not Hold Water
Washer pours water into the bowl, but does not fill. I can see water coming into the bowl up to a point at the bottom of the bowl and then water level never gets higher. If I stop the washer the existing water drains. Have also tried to move the cycle to spin in order to get clothes out somewhat dry and the spin cycle will not come on.
    President:
  • 1,294 Answers
What height is mentioned in your manual for your drain pipe (the outlet pipe for your machine) There should be a height (before u bend it downwards into the drain) or the water will just flow out........... And do not over-load your washer.
Posted on Apr 24, 2007
Our WaterRidge toilet tank will not fill with water
This sounds like the float is getting stuck , while the toilet is trying to fill if you see the float ball that is attached to a arm that pivots , if you lift the float up it should turn the water flow off from trying to fill the tank , some problems that can stop this are the rubber seal that lifts up when you press the flush button to allow water to flush the bowl does not seal back in a position so that the tank can never fill , sometimes the float ball can get stuck which stops it from rising up with the water level and shutting off the water , but my best guess is that the rubber seal has started to perish or distort and needs to be replaced you can find this right at the bottom of the tank and it is directly connected to the flush button ,so if you inspect inside the water tank and press the flush button you will see that it opens up and lets water pour into the toilet bowl but if a tight seal can not be made water will never fill the tank
Sep 26, 2017 | Washing Machines
I have a top load washer that is leaking water I pour water in an it comes out the bottom and I can't find where it's coming out
top right of photo is where the water flows through. so most likely in there. there is also a nipple on the side of the bowl that should have a pipe connected to it. check that. if you get under it, dry it, then put water in. the water is going to give itself away.
Nov 18, 2013 | Washing Machines
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Home
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Jan 12, 2011 | Eljer 141-0220-00 Toilet Tank White
I have a fisher & paykel IW810 washing machine that will not fill the bowl with water. While filling, it is also pumping the water out, in the autowater level sensing mode. I have gone into the command...
hi, reading your posting it tells me that the machine will fill on traditional wash but on auto fill mode it pumps the water out at the same time it is filling. i"m pretty sure it is your diverter . on auto fill mode it fills a little bit then the pump comes on and recirculates your water by pumping the water from the bottom of the bowl to the top of the bowl over the clothes. on auto fill mode it also activates the diverter to pump the water back to the bowl. on your machine the diverter is stuck in the drain out position so when it trys to recirculate the water it drains out the water instead . the problem could be a faulty diverter, control module or a broken wire.hope this helps, please reply if you need more help. good luck.
May 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Water is running through refill tube into overflow but bowl will not fill.flapper seems to be sealing,I even hold it down and will not change wwter level in the bowl.Where can the water be going?(CST924F)
Unless the water is running out onto the floor, the ONLY place it can go is into the toilet bowl. The amount of water in the bowl (known as the "water spot" - which is a reference to the size of the surface of the water) can be no greater than what the geometry of the bowl and trap will allow. Unless the trap is clogged, the height of the water spot is determined by the trap. Some newer toilets have a pretty small water spot. To confirm the size of your water spot, very slowly pour water into the bowl from a bucket.
Jan 29, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Washer won't start. water pours down sewer pipe
Hi, If the water is going out the drain hose, raise the drain hose so that its highest point is as high as the top of the washer. This should take care of the issue. If the water is coming out of the bottom of the machine, tip it back against the wall and look under the washer to see if a hose has broke or came loose.
If I can assist you further, please let me know.
Vic
Jul 18, 2009 | Roper RAS8445KQ Top Load Washer
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
I have a Admiral washer that fills with water but won't agitate
turn on your washer start programme while it is filling turn of power point if water still enters mchine you have a faulty water valve.if water stops there is a problem with the water level switch or hose that connects from outer bowl to pressure switch maybe perished or split.hope this helps you.
Mar 25, 2009 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
