Question about Microsoft Windows XP Professional
Pleas tell me how to run windows xp
I need to get it started ASAP
  • 409 Answers
Turn on your computer and go into the bios. Just sit there taping the delete key while the computer is starting up. Once in the bios find and change the boot sequence so the machine will boot from the cd rom drive. That will start the installation process. Follow the on screen instructions and have your key code handy. Good luck hope this helps. Oh and after your finished go back and put the boot sequence back to boot from hard drive.
Posted on Jan 01, 2009
    President:
  • 1,179 Answers
Put the installation cd into the drive and follow the onscreen directions. Hope this helps.
Posted on Dec 28, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 31, 2008
    Why the bad rating? I gave you the answer to the problem you posted.
  • Roy Lonsinger
    Roy Lonsinger Mar 06, 2009
    Wow a fixya & a TFT rating for basically the exact same answer I gave you yet you rated mine IA. Thanks.
  • 15,935 Answers
Push power on your PC
Aspire one d2500dr
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.
From the sounds of it, you probably did one of the two and now you cannot connect to the Internet.
If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
Oct 18, 2013 | Apevia Computers & Internet
I have an ibm net vista and i wan't to put a video car in it so it will run better the psu on is 185 watt so i don't know if it would work 1gb of ram pentium 4 ht 3.4 ghz windows xp (32 bit) so if...
Windows XP SP3 is No longer Supported on April 8 2014. Please Consider getting another computer that is upgradable to windows 7 or 8 or you will be left with a Machine that is worthless for the Internet
Oct 07, 2013 | IBM NetVista PC Desktop
OK all i did was turn my computer of by the switch because it was getting real slow and i couldn't do much because of the speed it was going so when i turned it back on it came up with the hp start up with...
You will require a start up/recovery/system disc as the boot sector has been damaged.
If you can get it to boot with a start up disc, run Scandisk to try and recover the sectors. If that doesn't work, reinstall Windows, bearing in mind most XP drivers are now obsolete.
Jan 23, 2011 | HP Computers & Internet
MNFISHERMAN TOLD ME TO USE THIS PROGRAM TO SYNC MUSIC WITH BUT I CAN'T FIND HOW TO DOWNLOAD IT.
As I am not aware what chat happened between u n fisherman.. Could u pleas provide more details 4 the same and the name of the software and its use? Thx
Aug 01, 2009 | Computers & Internet
Command prompt and regedit problems
My guess is when u uninstalled some of those visual basic programs, the uninstallation prosess damaged or uninstalled some vital file in your OS. I sugest you run a repair on your XP. I sure that will solve your problem.
You run a repiar by booting up from the XP-cd, after reading in all nessasary info XP will ask you if you want to reinstall your OS or if you want to repaire it, select REPAIRE, let xp do the job, reboot and you will be fine.
Good luck
Nic
Feb 20, 2009 | Intel Motherboard
What Driver Type?
What type of operating system does your computer have. Windows XP, Vista, ME...
The type of system tells you what to download.
Hope that helps...
Lbcoaster
Jul 13, 2008 | Sharp AR-5320 Black and White Copier
Driver for windows XP
pleas I woant the driver Scan Prisa 640P
Jul 05, 2008 | Acer Vuego 640U Flatbed Scanner
How to install windows xp boot cd on acer aspire 4315
When you first start the machine, you need to go into the boot menu and boot from CD drive, or go into bios/utilities set up and set the boot order to boot from CD first. Make sure your XP CD is in the drive, then just follow the prompts.
Jun 20, 2008 | Acer Aspire 4315 Notebook
Drivers
go to the link below for the downloads http://gb.lgservice.com/index_b2c.jsp
Sep 04, 2007 | LG LW20-EV Notebook
Microsoft Windows XP Professional Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
