Question about GE WJRR4170E Top Load Washer
Control knob will not turn to desired setting
I have a GE WJRR4170G0WW, Ser #FM909711G. The control knob turns but will not turn the dial to settings. If you grab knoband dial together and press real hard, you can get it to setting. It will run through all the cycles just fine once you get it to settings, so I dont think it is the timer. Any thoughts? Any help is greatly appreciated as I dont want to spend money I dont need to.
  • jimjacksona1 Mar 05, 2009
    Knob won't turn by using center knob. Can turn by flat ring.
    Understand how to remove knob but need to know how to order
    replacement knob and Part##.
    Thanks - Jim
    Mod wjrr4170g0ww
    It's been a great appliance!
  • 318 Answers
The timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Posted on Dec 28, 2008
Dial won't set
you can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Nov 19, 2013 | GE Profile WPRE6100G Top Load Washer
The control dial on my GE washer doesn't engage and let me dial a setting.
Is this washer new if so should be covered by warranty if not attempt to take top off the way that dials turning it looks like it aint making connection at back of fascia may have popped out at back of dial knob
Apr 01, 2013 | Washing Machines
I have a brand new Sherman Timeoff Water Timer Model 500 in a box, but there are no instructions. Can you help?
It appears that you turn the dial to any setting from 1 to 13 depending upon how much water you want the timer to dispense. The numbers show relative amounts from 100 total gallons to 400 total gallons, then the timer shuts off.
Gary
Jul 26, 2011 | Garden
The knob on my WJRR4170G0WW spins freely without turning the dial. Is this simply a case of changing the knob or do I have to worry about changing the timer as well? Thanks!
I just had the same thing happen to me. You have to replace the electronic part inside of the unit, where the knob attaches. That runs about $76.00 and I think I'll shop for a new machine.
Oct 26, 2010 | GE WJRR4170E Top Load Washer
How do you set the clock on a Pioneer DEH-1600?
To set the clock, please follow the following steps
#1
Press and hold the "SRC/OFF" button on your Pioneer car CD player until the unit powers down. Note that the "SRC/OFF" button is located on the top left of the Pioneer car CD player.
#2
Press and hold the multi-control knob, located on the left side of the CD player. Hold the multi-control knob until the words "Clock Set" appear on the CD player's display.
#3
Turn the multi-control knob until the words "Clock Set" are highlighted. Press the multi-control knob on your Pioneer car CD player to enter the clock setting mode.
#4
Turn the multi-control knob to highlight the "Hours" option. Press and hold the multi-control knob until the hours-place digits begin to flash. Rotate the multi-control knob until the desired value is displayed. Press the multi-control knob on your Pioneer car CD player to save your changes.
#5
Turn the multi-control knob to highlight the "Minutes" option. Hold the multi-control knob until the minutes-place digits begin to flash. Rotate the multi-control knob until the desired minutes value is displayed. Press the multi-control knob to save your changes and end the clock-setting process.
Hope this might help
Thanks
Oct 07, 2010 | Pioneer DEH-1600 CD Player
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
The dial doesn't turn with the knob pushed in, when we go to set the wash. but it does move manually with finger tips
The teeth on the knob are probably gone. To pull the knob off remove the clip between the knob and the dial and pull knob off.
Mar 01, 2010 | GE WBSR3140DW Top Load Washer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
GE WJRR4170E Top Load Washer Logo
424 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
