Question about HP Cameras
Can't load pictures on df780 picture frame
I purchased an HP digital picture frame and I can't open up the folder to drag and drop after I connect the USB. The computer completely locks up and the only way to unlock the computer is by pulling out the USB. What do I do?
SOURCE: 7 digital photo frame problems
Yeah, I just got one too and I have no USB thingy, and I kinda need my memory card.... hmmm.... maybe it should come with one. That's a bright idea huh! And how on Earth do you get music on it?!
Posted on Dec 26, 2007
SOURCE: Digital photo Frame
I went to Radio Shack and purchased an XD card reader with an USB connection.
I connected to my digital photo frame and was able to see the pictures on the XD camera card on the Polaroid digital photo frame.
Posted on Mar 06, 2008
Junoon007
  • 1011 Answers
SOURCE: Sungale 7" Digital Photo Frame CA700
Hello sir,
U should install usb driver 1.0 at the location of ur drive. or connect the camera with usb drive and install the driver version of 1.1. it will solved.
Thanks
Don't forget to rate the solution
Posted on May 11, 2008
  • 76 Answers
SOURCE: copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
Posted on Dec 02, 2008
  • 7 Answers
SOURCE: SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
Posted on Oct 05, 2009
I want to dowload some picture from usb on the picture frame
you probably have 2 possibilities..
1st ) is to insert the stick ..(card with the picture on ...and choose to play the slide show from it )
2nd) is to connect it to the computer ...and after that the computer will recognize it ..and you will find it in my computer folder by its name or as a removable device (this mostly in case it has a card attached)
Open the folder and inside you will be able to see the pictures that are already there ...top Load pictures just drag and drop pictures in this folder or copy and paste them..after that you will be able to see them on the frame ...make some slide shows with different folders ..or just play all..and it will change them on a preset time ..
Same thing for Mac..bu the frame will be visible on desktop..and same just copy pictures into it(be sure you do not cut them cause you will loose from computer this way ..so ..just copy ..and paste into the frame's folder
May 31, 2010 | Kodak EasyShare SV811 (8858946) Digital...
My pandigital frame is only letting me load 85 pictures
How big our your jpg pic files?
reduce them to 800x600: sh hold about 200+ pics.
also delete the pics that were pre-loaded
fred
Dec 18, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
How to copy music files to my Smartparts
If you open up My Computer, you will see your picture frame listed as a removable device. Open that up and you will see a folder called music. Drag and drop the music into that folder.
Apr 04, 2009 | SmartParts SPX8 Digital Picture Frame
I don't know how to download music to my Pandigital frame.
Must be Mp3 format.Music files copied directly from a CD will not play on your frame. All music needs to be converted to a MP3 format, and then copied to your frame. This is really a simple issue of drop and drag after that. Open 2 windows explorer windows. You will find windows explorer in your start menu. Find the removable drive maked pandigital. Locate the audio folder, and click open.
In the second explorer window locate your MP3 files. Drag desired files to the first explorer window.
Feb 14, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Unable to load more than ~50MB into df780 digital picture frame
I had the same problem on a 128 mb memory. I figured out that it can only load a certain # of objects/files. So I started from scratch, and I created a new folder in the pandigital and copied all the files/photos/mp3's into that 1 folder. Thus 1 object. I was able to fill the entire capacity after that. I can't believe I actually helped solve one! I hope it works for you...
Jan 07, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Copying pictures from PC to the memory card.
When you connect your camera to the pc, via usb cable I presume, don't use the software that came with the camera, instead open the MY COMPUTER icon on the desktop, or in the windows START BUTTON. Your camera should in fact be recognized and appear as a new disk drive with its own drive letter or name.
If that happens, open the new drive window, and you should be able to see the folders that your camera uses to store pictures taken with it. It may depend on the picture frame requirements, but seems to me that you can now just drag and drop, cut, copy and paste any pictures you want right to the memory card drive, and I would not put them in any folder created by the camera, just on the memory card itself.
The other alternative is to purchase a memory card reader/writer for your type of card. They usually accept every card out there, and now you would be able to use that device to copy to and from the memory card without the need for a pc.
Hope that helps.
Dec 29, 2008 | Casio Exilim EX-S500 Digital Camera
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
I cant figure out how to download pictures onto the frame from my pc
Connect the frame to the pc. Look in my computer - it will be a device with removable storage. - drag and drop pics or a whole folder of them to the frame.
If the PC isnt picking up the frame at all... try a USB port in the back of the computer. Also make sure the frame is powered on!
Dec 10, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Cameras Logo
107 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
