Question about Microsoft Xbox 360 Console
Disc drive won't work
Disc drive won't open or close automatically i have to dot it myself then the disc won't spin. Is this something I can fix or do i have to buy a new one? Do i have to buy the same brand as the one in the machine and where can i buy one?
  • Anonymous Dec 28, 2008
    i have the same trouble how can i open the drive manualy?
  • 44 Answers
Alright, this means that your disc drive went out.... the part runs approximate 50 bucks off of ebay... that includes shipping and handling... YES! model # for disc drive must be EXACTLY the same... it will say right on your disc drive what kind you need.... For a tutorial on taking your xbox 360 apart... go to this link: http://www.youtube.com/watch?v=Uj2A7mGGjuY&feature=related .. Alright after that.... DO NOT, I REPEAT DO NOT THROW AWAY YOUR OTHER DISC DRIVE... YOU WILL NEED IT!. or at least the chip from the inside.. This video shows you exactly what to do with your new and old disc drive.: http://www.youtube.com/watch?v=T_xSsNmjqKI&feature=channel . I had this exact same issue and it works wonders now. you see the chip in your old disc drive has memory for your specific xbox ... since each is unique... GOOD LUCK! :D
Posted on Dec 28, 2008
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
When I power up my LG RHT397H the DVD tray opens, it will not accept any discs. If I press CLOSE the tray closes then re-opens. The fault only affects the DVD drive - the unit records on the hard disk, and...
Sounds like possibly the Spin Motor is bad and not spinning up the disc's. That's usually what I've found, if it were the optics assembly, it would take a long time before it finally gives up and say's something like "No Disc", "Disc Err", etc.
Jun 12, 2010 | Televison & Video
The disc won't spin
Hi, It could be one of 2 things, either your laser is on its way out or the motor in the dvd drive has run out of lubricant. The latter is quite obvious as the drive will be noisy when spinning!!!, if ur tech savvy and are capable of doing so, remove the drive from the xbox and open up the drive casing, the motor is situated under where the disc sits on the little black disc.
There are 3 screws holding the motor in place, remove them and with gentle pressure pull the black section from the motor, clean thoroughly then place a couple of drops of wd40 or three in one oil onto the shaft. Re-assemble and that should fix your problem.
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
Problem with disc reader
the motor that drives the laser is broke solution get a new drive or motor
May 04, 2008 | Microsoft Xbox 360 Console
Xbox 360
Listen to your dvd drive to see if it spins up or not when you put the disk in. If it does spin normally then you will be need a replacement laser.
If it does not spin correctly. The motor is stuck, sometimes if you open out the tray and stick something into the drive and give it a spin it will free the drive.
Check out this link if you have the Hitachi dvd in your xbox360
Link
Mar 18, 2008 | Microsoft Xbox 360 Console
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Xbox 360 opens automatically
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
Jan 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
Oct 07, 2007 | Microsoft Xbox 360 Console
X box 360 broke
The only solution really is to open your 360, open the DVD drive and try to see if you can posibibly unfreze the drive. Its possible that you are going to have to put a new drive in it. I would just send your console off, even though you'll have to wait on the Halo experience. If you do open your console, you're going to void your warranty and Halo may cost you a whole 'nother $300. When and if you open your console, you will need to check if the laser is operational. With the console open (check Google for a huge list of how-to-open-it guides) go on ahead and remove the cover from the DVD drive, but keep the DVD drive still placed in the Xbox 360. Hook-up your power and video cable and go ahead and press the eject button (you can place this back on without putting the console back together, even though its ness. to take it off during the disassembly) and watch the tray. Listen and watch for any resistance, stuttering, swaying to one side (hold the console flat), and scraching. It should be very smooth and automatic. Then procede to close the tray but this time watch the laser. Don't look directly over the laser, but try to catch if it lights up (red) and it may even move a little at you. Again, everything should be smooth and automatic. Now for the slightly tricky bit. Take the worst possible game in your collection (King Kong?) and place it on the open tray (open tray, place disc on tray) and then close the tray. Hold the 360 as flat as possible or don't hold it at all (the latter option is better if you have a table nearby) and watch the disc, always ready to press the eject button if something goes wrong and your disc spins out of control and/or you hear scratching. An alternate, safer method of checking to see if the disc spins is to take a fridge magnet and place it on the center spindle magnet and let the disc spin (the magnet, just like the one in the DVD drive cover, hold the disc in place as it spins at super-sonic speed!). Just use the very simple process of emiliation to determine the root cause of your DVD drive problems and then repost. Just remember that this voids your warranty and only open your console if you're sure that you want to try to fix it and you are willing to accept that you may be left with a brick afterwards. That's it for what you should do to diagnose the problem, good luck!
Sep 30, 2007 | Microsoft Xbox 360 Elite Console - Black
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Microsoft Xbox 360 Console Logo
682 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
