Question about Intel Motherboard
Computer wont work when 2x2 connector is plugged in
When i plug the 2x2 connector into my motherboard my computer wont start, it just turn on for like 1sec then turns off. When its not plugged in and just the 2x12 one is, all the fans on the video card, cpu heatsink, and case fans turn on fine and the computers stays on. But i cant do anything because the screen is just blank and nothing happens. I'm pretty sure the psu is not the problem because it ran my other computer just fine. And its 730w so im also pretty sure lack of power isnt the problem either. I dont think that the problem is it getting shorted out/grounded on the case either because it wont work sitting on my table either. Can anyone help me?
    Genius:
  • 1,066 Answers
Sounds like a cpu problem, or a failing power supply.
Posted on Dec 29, 2008
My power supply has a 4 pin connector to the mb,, but my gigabyte mb has 8, which 4 do I use?
The motherboard can support a 2x2 (4 pin) or 4x2 (8-pin) connector. The motherboard employs a foolproof design, as the socket on the motherboard is keyed to prevent you from installing the 2x2 in any position other than the correct one. The image below was extracted from page 24 of the manual.....you plug should be in pins 3,4,7,and 8.
5gdyeavkqd8hdkhmptocjzpg0wkeeaegjyamakqf5acalia8apatkaycugdwakbkqbwbsaviaqepahgbiccgdackbeqagjsapakqe5agalia8ajaskacauglyaebkqb4asaniawap+x9q3vizrp3bpwaaaabjru5erkjggg==
Jan 19, 2012 | Gigabyte GA-MA785GM-US2H Motherboard
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
Intel D945GCLF - No post, No video Signal
Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
Sep 22, 2009 | Intel D945GCLF Motherboard
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
My computer won,t turn on
2x2 or 2x4 Power Connector Not Plugged In
If the power supply cable with the 2x2 connector or 2x4 connector (depending on your desktop board), is not plugged into the 12V processor core voltage connector located near the processor socket, the system will not boot up. You will see lights onboard and on the chassis front panel and the processor fan will spin, but nothing will appear on the monitor. See figures below for cable placement.
  • Make sure the fans on the processor are connected properly and running.
  • Make sure that the thermal interface material or the thermal grease is applied to the processor properly.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly.
  • Make sure that the air intakes for the external fans are unobstructed and have at least several inches away from walls and other items.
  • Oct 08, 2008 | Gateway 3250S PC Desktop
    Computer stopped working - I see a spark when I plug onto motherboard
    the spark you see is a shorted power socket on the MOBO, the spark is shutting down the power supply for protection. You need a new board.
    May 19, 2008 | Intel D945GTP Motherboard
    Upgrading BTX Motherboard
    Hi, I think you are looking at the front USB pin aray connector. The on/off switch and LED light pins are usualy along the edge of the board nearest the front of the case. They will be marked with ID: lettering:- pwrs, hdd led, rs-sw, pwr led. If your case has one block plug you will haave to gently seperate the segments and plug them on one at a time. The power and reset switch will work either way but the LED will only work when plugged the right way around, it wont do any harm if they are plugged backwards they just wont work, so experiment. regards mistyman
    Sep 21, 2007 | Intel Motherboard
    Intel Motherboard Logo
    87 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
