Question about Toshiba Satellite R15-829 Tablet PC
Booting from a USB Stick
I am running Ubuntu on my Toshiba Satellite R15-829 How can I boot it off of a USB Stick
    Scholar:
  • 35 Answers
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Posted on Dec 28, 2008
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
When booting, the system hangs at Windows XP logo. It does the same when booting (or trying to boot) into safe mode. What could be the problem and how do I resolve it? I tried to use the Windows XP CD to...
You can access the BIOS usually by pressing "esc", "F1", "F8", or "F12". One of those buttons
should work.
As for the hang up at the logo, it sounds like your hard drive might have crashed. The same thing
happened to me on my Vaio.
Feb 09, 2011 | Toshiba Portege M700-S7002 Tablet PC
We understand that your problem is: Hi please help me i dont know what to do i purchased a used compac tc1000 tablet pc on ebay for college and It had ubuntu installed on it and not windows xp it did come...
Hi First you need to make the USB CD-rom Drive as the first boot device by going to BIOS setup by tapping F2 when the system turns ON , after changing the boot order insert the first disc and restart the computer it should run from the disc.
Nov 28, 2010 | Compaq tc1000 Tablet PC
How do i get to the BOIS on me R10? When it boots, there is no prompt for a "Hit X key to enter BIOS"
Try F2 whilst booting,if you get into these pages navigate with the "tab" and "arrow" keys. Save and exit after selecting"Enter -key") or restore to defaults--good luck!
Davey Snake!
Oct 25, 2010 | Toshiba Satellite R10 Tablet PC
Can I Install Linux via USB Flash Disk for mu Panasonic CF-18, plz help me
Yes, you can do it. I recommend you install Ubuntu Linux. To do this you need the following: 1. Download the distribution from the site www.ubuntu.com/desktop/get-ubuntu/download 2. In paragraph 2 "Burn your CD or create a USB drive" on this page, select "I would like to create a: USB stick " 3. Follow these instructions
May 30, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toshiba 3505 not booting from usb cd rom
OK, Do 1 thing, start pc press del go in side of BIOS.
Set the 1st booting drive as USB CD ROM. and save that. then restart your system.
Jan 30, 2010 | Toshiba Portege 3505 Tablet PC
Portege m200 wont boot from cd or anything.
look at this page
http://blog.ryantadams.com/2008/02/01/how-to-boot-from-the-network-pxe-boot-with-tftp-and-windows-pe/
it works very good.
Mar 27, 2009 | Toshiba Portege M200 Tablet PC
Install ubuntu linux on a ST4110 Tablet
THERE ARE 2- VERY GOOD WAYS, LINUX IS FREE SO YOU CAN GO TO THERE WEBSITE AND BURN ANY OF THERE DISTROS ON A DISC-OR-DVD, OR YOU CAN ALSO GET THE DISCS MAILED DIRECTLY TO YOU THROUGH THE SAME SITE FOR ANY DISTRO YOU WANT. UBUNTU HAS ITS OWN SITE AND THEY HAVE LINKS THERE WHERE YOU CAN GET THE DISCS ALREADY DONE.. HAVE FUN WITH THE PENGUINS, JON T...
Dec 07, 2008 | Fujitsu Siemens Stylistic ST4110P Tablet...
Taskmanager popup
Let's start as simple as possible:
Do you have a loose connection / glitch at the power-connector? Check and solder (link to manual for disassembly is further down in this document)
To me this looks like a stuck key (not necessary one on the keyboard):
create live-usb-ubuntu:
1. download and burn ubuntu 8.10 to cd.
2. boot _any_ computer with it, connect >1GB USB stick.
3. System --> Administration --> Install to live usb
4. Boot from live-usb-stick that you just created
5. open terminal (Applications --> Accessories --> terminal)
6. paste this: sudo apt-get install xev
7. paste this: xev
8. hover with mouse over white box
9. make sure not to press any keys or move the mouse. Now flip the screen or try to recreate a situation in which the task manager would pop up in windows.
10. what's the output in the terminal window? Try to pinpoint exactly how and when the events are generated.
There should be no event generated, when you physically flip the display (which means you don't have to replace the hinge).
Press every single key you can find on the laptop. Verify that each key generates exactly one event.
If you find that there is a series of events generated without any key pressed, try to clean the malfunctioning key. (Service manual for disassembly)
It might possibly be a broken hinge (20USD). Flipping the display and pressing soft keys (Q, rotate, e) does not generate events in xev. Any other button does.
Sep 29, 2008 | Compaq tc4200 Tablet PC
Toshiba satellite 1115-S103 I can't boot up
It seems like your computer is booting from the network. This means that it is not detecting the Hard Drive. This error shows up when the hard drive is already busted or is not working anymore. You'll need to call toshiba for repairs or just get a brand new hard drive and install it yourself. It's pretty simple.
Aug 26, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite R15-829 Tablet PC Logo
2,652 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
