Question about Sony DSR-20 DVHS VCR
Sony DSR-20 We have recently aquired 2 Sony DSR-20 decks. When we try connecting the firewire ports to any other equipment (computer, Firestore, other decks, etc) they act as if they are not connected. Does anyone have any tips on what fails on these VTRs in the firewire area?
  • Anonymous Apr 29, 2009
    same thing...
  • George Thomas May 11, 2010
    the firewire ic might have blown in back supply from the pc. check with a service centre and replace if necessary. never connect or remove firewire cable when mechine is connected to power evenif it is OFF also.
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Sony DSR-11 Will Not Recognize Timecode
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Posted on Sep 11, 2007
Shuttle83
  • 1139 Answers
SOURCE: DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. http://forums.creativecow.net/readpost/35/856108 It has helped me
SOURCE: Sony DSR-45 Lost Firewire Signal
Port's fried for sure -- that's a classic Firewire Port Burnout problem. Could be a cheap repair if you can take it to someone who's not afraid to get their hands dirty (soldering, perhaps). I don't know how integrated the port is to the unit (like on a laptop) so good luck!
Posted on Sep 20, 2007
SOURCE: DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
http://www.fixya.com/support/t178954-tape_stuck_inside
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Posted on Sep 05, 2008
My DSR 45 Firewire port is fried. Any idea which Problem with the Sony DSR-45 Mini DV VCR
DSR-45's firewire port is held on a separate littlle circuit board, easily reached from the underside of the deck. Remove the bottom panel, unplug the cable from the Firewire board and there is 1 screw to hold the firewire board in place. The part is called DV-032 on Sony's Parts website and costs about £30 UK including postage to buy.
Sep 16, 2011 | Sony DSR-45 Mini DV VCR
DSR-1500
As far as I know, the deck you mention has a firewire port as standard.
Jan 07, 2010 | Sony DSR-1500 Mini DV VCR
DSR-1500 firewire port doesn't work. Any
It may be that the firewire cable has been inserted the wrong way round. Unfortunately this is a common problem as it is quite easy to do this especially when fumbling around with limited access behind the deck. Worst case scenario is that the Firewire circuit board has been fried! Firewire connection carries 30 volts, and if this connect to the wrong pins - pop goes the board. It's a £300 job to fix (I think). But first of all try pairing down any patching / connection to other equipement to a minimum to ensure that there is not something else in the chain that could be causing the problem.
Oct 06, 2009 | Sony DSR-1500 Mini DV VCR
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Aug 26, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Tech Friends -
Jun 19, 2008 | Sony DSR-11 DV / Mini DV VCR
Firestore FS-4 no longer recognized as external drive by Macs
bad firewire port try getting a new firewire card throw usb many or pcmia pci card for desktops
Jan 30, 2008 | Video Cameras
Sep 11, 2007 | Sony DSR-11 DV / Mini DV VCR
Aug 24, 2007 | Sony DSR-45 Mini DV VCR
Aug 15, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-20 DVHS VCR Logo
4,374 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
