Question about DISH Network IR Remote Control
Hello. My name is Jerry I have a dish net work I want to set up my dvd recorder with this remok control I have the 510, Part # 118579, 132578 remock control
  • 374 Answers
Jerry,
You will need a 6.4kit or 6.3kit and remote to communicate with the 510 receiver. The remote you have is a 6.0 and may work with the kit but I have never tried that application before and Dish does not recommend that remote as a replacement for the original. An 8.0 remote would work also. Thanks for using Fix Ya and let me know if I can be of further assistance.
Posted on Jan 01, 2009
How do i burn movies from dish network? How do i view dish network with the unit on?
Hi abracadab628my name is Mike Houston of DISH Network and after reading over your post andthere is a simple solution to your recording questions. You can connect you're Phillips/Magnavox DVD/VCR and run it through the DISH Network receiver and set thetimers up on your VCR/DVD player.
Mar 29, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I HAVE DISH NETWORK AND WANT TO CONNECT MY NEW ZV427MG9 A UP TO RECORD A SHOW, ON DVD. MY TV HAS RCA CONECTIONS IN THE FRONT, BUT I HAVE TO BE ON VIDO 4 TO USE THOSE. MY DISH BOX HAS A SET IN THE BACK, I...
you need to hook the dvd recorder up to the dish net work, yellow to yellow port, red to red port, and white to white port.
the dvd recorder should have had a book in with it to show you how to hook it up
Mar 03, 2011 | Philips Magnavox DVD+R/+RW Recorder/VCR
HOW DO I PUT A CODE TO PROGRAM MY DVD PLAYER WITH THIS DISH 20.01 REMOTE
Hello djdannyvey, my name is Michael Hurst with DISH Network. On your remote there should be a DVD button on the top of the remote. There are 2 ways you can program remote to your DVD player. You can use a remote code for the model/maker of the DVD player, to do this hold the DVD button down until all buttons on top of remote light up. Let go of button and put in the code. Then press # button and then the Record button. The next option is a power scan. Withthe desired equipment on, press and hold the correct Mode button until all modebutton backlights illuminate, then release. Press and release the Power button.AUX Mode: Before pressing and releasing the Power button, Press 0for a TV, Press 1 for a VCR/DVD, Press 2 for any other device. Then Press STAR(*) Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff. Press the POUND (#) button. If the code entered is valid for the remote,the mode light flashes three times.
Apr 13, 2010 | DISH Network IR Remote Control
How do I make it a region free player?
Hello Cbeard799,
Here is a link that you may find usefull.
http://www.dvd365.net/
just click the icon that says 'CODES' at the top of the screen then click on the Panasonic tab.
If for some reason you dont find your model number then you could always try a few of the other unlock codes for the Panasonic brand they may work with your dvd player.
Hope this helps you out, If so then please leave a thumbs up.
Cheers little dish fitter.
Oct 23, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need code for my dish network remote to operate sony decorder mod
I had a device (I forget the brand name) but I could not find the code. There is a way to check all the codes one by one and it didn't take me very long. I can't remember exactly how to do it though.
it was something like you enter this one specific code that allows you to keep trying to turn the device off and each time you try it will go to the next  code. When the device turns off you know you have the right code and you press a button to lock it in.
I did it through bright house but I would think that dish has something similar. I found it on the bright house website from the problem solving menu.  Try looking for something similar at the dish net website.
Hope that helped. Wish I could be more specific.
Jan 05, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Dish Pro record code for Mag combo
ZNREL, I've done this with Dish Pro before. Setup the Dish remote to control the Mag combo in the VCR position. Press the SAT button and select the guide. Go to the program in the guide and select it. The "record this program" routine should pop up, set it up. Here's the key, make sure the Dish remote has the VCR button selected and that the remote is placed where it can "see" the Mag combo. At the set time, the Dish remote will change the DishPro to the proper channel and then issue s "record" command via infrared to the Mag combo to start recording. DishNet has all of the device codes to their remotes downloadable from their site.
Mar 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd recorder grunting, not recording
May be mechanical failure in the sled area. The cause may be dirt or warn parts.
Difficult to really comment properly on this one...
Jerry G.
Mar 02, 2008 | Panasonic DMR-E50 DVD Recorder
Connecting my DVD Recorder to Dish Network so I can record
If it is hooked up right to record as the program is on. Then make sure the input is set correctly, the tv should show pic from ext-1 the e-55 should be on channel 3. This should solve ur problem.
Jan 04, 2008 | Panasonic DMR-E55 DVD Recorder
Recording to DVD on samsung recorder from dish network dvr
Connect the "yellow, white , red) jacks from the Satellite to the same colored inputs on the DVD. If you use "Input 1", for instance, set the dvd to record on Input 1. Set Satellite to desired channel. Good to go.
Sep 08, 2007 | Samsung DVDR120 DVD Recorder
DISH Network IR Remote Control Logo
73 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
