Question about Gateway M210S PC Notebook
Gateway laptop on/off switch broken
I have a Gateway laptop. Everything works except the on/off switch. (I took it apart to clean off the beer that was spilled on it and it worked after I cleaned it, but the switch was a little flaky). Now the switch doesn't work at all. I know that it is getting power because the power LED on the keyboard lights up when I plug it in.
Power button not working
Do you mean, it won't switch on?
Jan 21, 2014 | Gateway NV52L06u Laptop PC
Gmc envoy 2003 driver windows not working
Take apart again, and clean all connectors and try again. Maybe some rust build up on connectors.
Oct 31, 2013 | Cars & Trucks
Fix a broken power button on a Gateway laptop
See section Replacing keyboard at http://support.gateway.com/s/Manuals/Mobile/8512564.pdf
Sep 07, 2012 | Gateway MT6728 Notebook
I took apart my laptop to re soder the power jack, i fixed that an when i reasembled the computer and turned it on, everything came on except the screen.. i dont know what the problem is?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Aug 17, 2011 | Gateway Solo 5300 Notebook
I spilled a fairly small amount of beer on my gateway
You might be able to do it yourself, though in the worst case there are companies that replace motherboards for about $150. The problem you are experiencing may be a display inverter problem, the easiest way to test this is to connect the laptop to an external monitor using the VGA port (usually blue). If it displays what you would expect, then it is most likely not the motherboard. New LCDs for most laptops are also in the $150 to $200 range, and are fairly easy to replace on some models of laptops. Inverters are less than the LCD in most cases. I would not recommend doing the replacement yourself if you are not intimately familiar with the inner workings of notebook computers.
Dec 16, 2009 | Gateway M-1625 Notebook
I spilled a small amount of beer on my gateway m-1625 laptop and now everything seems to be working except the screen so i am trying to take it apart. i have taken most of the screws out but it still wont...
If your have the time, Hose down the pc with windex, through the leyboard, and any other openings that are available. Set the unit aside for at least three days in a warm area. This will dissolve any beer residue and allow the windex to totally evaporate. Try to run the unit after you are fully sure that all of the windex has evoparated.
You should be good to go unless you have burned out the video processor. If the screen still doesn't work, you can attach an external monitor to test it. If it works, you haven't burned up the processor, but you most likely have ruined the screen circuity.
If that is the case, then good luck. Go online and goole Gateway Notebook Repair. You'll have quite a few choices to select from.
Rich
Rich
Dec 15, 2009 | Gateway M-1625 Notebook
MT3705 Fan broken
wow this is quite the job you are undertaking but can be done, as far as amanual to take this aparty the only way i know to get one is through gateway themselves and good luck with that, having said this i took apart my laptop and replaced the fan but it wasnt easy and theres a bout 100 screws
Aug 31, 2009 | Gateway MT3705 Notebook
Spilled onto Acer Aspire laptop
I suggest you download for $6 the service manual for your laptop here
http://www.9manuals.com/gateway_sm.htm
You take it appart and clean everything electronic board component side and wired side with alcool (not beer, something like 90%), you wash the plastics, and build everything back together.
Before pushing the power button, pray a little bit ;)
20mn was too short anyway , next time it's two days min. by hot days.
Good luck and don't forget to vote,
cheers
Jan 03, 2009 | Gateway CX2608 Notebook
Gateway 450sx no power
Needs physical repair. No help without some new parts. The "little piece" latch is necessary. The bay thinks there is a device there and there isn't. The POST (Power On Self Test) program won't allow it to startup if a device is missing.
Jun 18, 2008 | Gateway MT3705 Notebook
Gateway M210S PC Notebook Logo
293 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
