Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Front load washer poured water from bottom
Too large of a load (teenagers) and it was unbalanced. Heard a loud pop then water poured from the bottom until it was empty. Seems to run now, but still leaks from base and there is some black grease
  • ugotrachel Feb 13, 2009
    water leaking out from under door
    Problem Solver:
  • 11 Answers
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Posted on Dec 28, 2008
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
SOUNDS LIKE THE WATER INLET VALVE COIL BLEW A SEAL? DOES IT STILL POUR WATER IN AFTER UNPLUGGING IT? IF NOT THEN U MAY HAVE AN ISSUE WITH THE TIMER OR BOARD SENDING ELECTRICAL SIGNAL TO THE INLET VALVE? BUT THE POP LEADS ME TO THE INLET VALVE CHECK IT WITH A MULTI METER
May 25, 2014 | Asko W6661 Front Load Washer
One of the springs on my washer broke after I tried to wash a large rug (stupid move I know). After replacing the springs and replacing the door gasket., I placed a packet of Tide washing machine cleaner...
I would imagine that you accidently disconnected the water level pressure switch and the machine never new the water level had been reached. However a "pop" is a bad thing electrical and I hope you didn't fry your control panel. The fuse shoud be on the back of the unit by the power cord. Obviously unplug it before servicing it.
good luck!
Apr 16, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Started washer, heard 'pop', water started coming out of bottom
Thats not good. Sounds like the seal blew out. Inside the unit there are seals that seal up the parts where they are bolted together. Also there is the pressure connection that could have blown out as well. To determine which is the problem you will need to dissassemble it.
Jun 22, 2010 | Karcher K 593 M Electric Pressure Washer
Haier washer machine HLP23E makes a noise
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Jan 04, 2010 | Haier Washing Machines
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
I have a front loading GE washer that is extremely loud on spin cycle. How can i remedy this?
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs,shocks, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Nov 27, 2009 | GE WSXH208A Front Load Washer
Maytag Performa washer immediately drains water out of the bottom
owww. you d have to remove the front panel to see what hose has split or perhaps the door boot has developed a tear. sure it will be quite obvious as to where wate ris coming form after removing the front panlel
Oct 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
The water is not being pumped out of my kenmore front loader washeer machine
Unplug the washer from AC
Open the bottom access panel (3 screws on bottom lip)
open the large filter in center,
be ready for a lot of water, mops and rags ready. water vac is really handy .
Clean all the debris you find in the filter, reach in an spin the little propeller and make sure it spins freely.
pour in a cup of water inside the tub does it drain down freely.
reassemble and test.
front access panel has a switch so it has to be closed back.
Jan 26, 2008 | Kenmore 43142 Front Load Washer
Washer won't rinse
when yr washer does not rinse, it could be that your outlet is clogged. Ensure that yr outlet filter is free from any kind of blockage. Check this, it is a small door in front of the machine bottom. Plug off the wall & clean out, expect some water to come out when you open it. If this is not the case check out your outlet pump.
Sep 26, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
189 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
