When you shut the door the pump starts running.
SOURCE: More info on my dishwasher will not start
hi there,
thanks for the info. you are correct it's the touchpad. you can get one at www.reliableparts.com
let me know if can be of more help.
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
SOURCE: My Frigidaire dishwasher will not start.
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
SOURCE: Frigidaire Dishwasher Model:FDB1050RECO - When
same problem, wash light would flash, just like if the door was open during the wash cycle....took door apart and suspected the door switch was bad, fiddled with the wires that go to the door switch and the washer worked after that. so i had the door disassembled and used my hand to close the door latch switch then wiggled the white and black wires that go into the bottom of the switch, that is when it started to work.
wiggled with the wires for a while more while the washer was working to make it stop and start, until i found a good spot where it stayed working. been a few days and it is still working. need a new door switch if'/when it quits next time.
the door switch keeps the washer from running with the door open, it tells you the door is open by flashing the "wash" light when you try to start it. cheesy switch, my washer is only a few years old. i tried all the other things suggested, power on and off and hold down different combo's of buttons while standing on your head with your right eye closed, none of that worked so out came the screw driver.
figured if it was coming out to go to the dump i could not hurt it much more than it was at that time.
anyhow door switch was the problem, i hope this helps more people out there, i was close to throwing it out after not finding much for helpful advice online.
SOURCE: I have a frigidaire gallery
It would be helpful to have the full model number of the dishwasher.
Most likely the door seal is swollen and may need replacement.
Alternatively the micoswitch in side the latch assembly is not making contact with the latch tongue.
It is also possible the springs at the door base are too tight and need to be adjusted.
need the model number.
Good Morning friend, thanks for your post!
From the information you have provided the door gasket on your Frigidaire dishwasher continues to come loose. Typically, when your gasket starts coming out you may need to have a replacement gasket installed. I would recommend operating the gasket you need from your manufacturer and replacing it. I hope this information is helpful. -Matt
Hello seagraves98 - Since you have already confirmed that the spray arms are moving freely and the filter has recently been cleaned, I will suggest verifying that there is enough water pressure coming into the unit. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
