Question about Nikon COOLPIX L3 Digital Camera
LENS ERROR ON COOLPIX L3 CAMERA
I WAS TAKING A PICTURE ON THIS CAMERA AND LENS ERROR CAME UP AND WON'T GO OFF. i CHANGED BATTERIES AND THAT DIDN'T WORK PLASE HELP
Not the same problem but hope this helps. I went to get it looked at by a dealer and they said it would cost 180 bucks. They said it was not worth it. Ok this is what I did to fix it. Mind you it can be a little difficult for the not so tech savy. First remove the batteries, then take all the screws out on the outside of camera, dont forget about the 2 under the battery cover and the one in the AV port. Carefully use a small flat tip screwdriver to pry the two plastic covers off. The hard part is over, now pull up the LCD, it is stuck on by double face tape. There is a silver cover 3 more screws to remove. Ok now for the easy part. Where the screen attaches to the motherboard there is some black tape low and behold under it is a connector. On my camera it was not connected very good. I pushed it back on and put it all together and now it works. 180 bucks saved. Hope this helps.
Posted on Dec 30, 2008
It keeps saying lens error
Here are some troubleshooting steps for the lens error problem. And here's a video summary of those steps:
Jan 13, 2013 | Canon PowerShot S3 IS Digital Camera
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
Camera won't turn on anymore
If changing battery doesn't help, then you better go through this blog's article about camera lens solution, http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Please don't try to do anything if it's under warranty. Good luck
May 23, 2010 | Kodak EasyShare C913 Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Nikon Coolpix S210 Digital Camera
My d40 won`t take pictures
Try Blow cleaning the Memory card slot ... sometimes dust does that
Oct 05, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Error
there are two possible problem of your camera...change first the lens or try other lens if you have,normally the lens have an error is on wide position...if nothing happen when you change the lens the possible problem is the shutter of the camera.......
Aug 24, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Nikon COOLPIX L3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Computer Links
Are you a Nikon Camera Expert? Answer questions, earn points and help others
