Question about ASUS M2NPV-VM Motherboard
Computer will boot but will only displays press sel to enter setup and F12. No lights on PS2 keyboard. Tried USB keyboard no luck. No lights. CPU Fan is running and the hard disk is spinning. CD rom opens but still wont continue to boot in windows
    President:
  • 948 Answers
Try another PS2 keyboard.
Try a USB keyboard with a PS2 adapter.
Try resetting the bios using the jumper on the motherboard.
Try removing all of the dust you can from inside the case, reseating all the components and going through the process again. If you can't get it to recognize that a keyboard is installed and can't get the bios to continue despite the no keyboard error you'll have to replace the motherboard.
Posted on Dec 29, 2008
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Can not enter Phonix BIOS A.07 setup
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Gene Reinhard!
Another key to tap repeatedly when you computer is first powered on is the delete key.
Also some-times USB keyboards are not detected quick enough to actually register your key pressing at the appropriate time. Overcome this by using an older keyboard with a PURPLE PS2 connection.
Take care!
Feb 10, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Windows wont start. dont know how it happened.
Does F2 mean to enter setup or does F12 mean to enter setup, Press the particular key on the keyboard to enter setup and Go to Exit using your up-down keys on the keyboard (it varies with different motherboards) and go to Load Optimized Default then Yes and press F10 - Yes and it will automatically restart the system, b2.jpg if both are not displaying anything to do, restart the system and press Delete button and follow the same instructions as mentioned above. (If the BIOS screen is similar as displayed above, then just highlight the Load Optimized Default using your Up and Down Keys on the keyboard {Y for yes, Enter for OK}).. It's will boot from the hard disk as default not from the CD-rom..Good luck...
May 10, 2010 | Dell Inspiron 530 Desktop Computer...
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Dell OptiPlex GX280 PC Desktop
I can't install vista any mouse or keyboard detected
Often times this happens when using a USB keyboard / Mouse.
Or when using a USB keyboard through a PS/2 Converter.
Try using a PS/2 Keyboard if available
(Small Round connector with a small amount of pins, similar to a S-Video connector.)
Also. Access your BIOS settings and assure that you have Legacy USB keyboard support.
Depending on your computer the BIOS / Setup Menu / Options Menu/ Etc. can be accessed by pressing the following key during boot:
F1
F2
ESC
DEL
F12
Let us know your setup(KB and Mouse Port type), and if you have any other issues.
Good luck
Apr 14, 2009 | ASUS P5V800-MX Motherboard
Laptop A3 not booting up
Sounds like your hard drive is not booting and that your keyboard isn't responding to your pressing F2 and F12. If you can locate a USB external keyboard or if you have a round PS2 port for an external keyboard/mouse - plug into the laptop with that then press F12 while the computer is booting, press it a few times to be sure you get it in the buffer - then the boot manager should show up. If it does, choose to boot the Hard Drive if available - same with pressing F2 - Setup or Bios CMOS Settings should be displayed, here you can try to boot from the Hard Drive or Check to see if the hard drive is being recognized or not.
You may need a new keyboard if your laptop keyboard doesn't get you into either menu, and to either make sure your hard drive is responding and can be set to be the default boot device.
Mar 23, 2009 | Toshiba Tecra A3 Notebook
Warning message at boot up,non-responsive keyborad
Try this! Open your CPU there you will find CMOS battery remove it and reinsert and there will be a BIOS pin remove it and reconnect. Now Switch On the system.
Jan 13, 2009 | Micro Direct (SYSMDBGAMBASE004) PC Desktop
ASUS M2NPV-VM Motherboard Logo
257 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
