Question about Microsoft Xbox 360 Controller
Wired Controller not turning on
When I plug it in the upper left and bottom right lights come on but the controlle does not work. Any help?
    Problem Solver:
  • 7 Answers
When you plug it in hold down the X button in the middle of the controller. When it blinks, sync it in the 360, but if it doesn't connect blow the USB connector at the tip of the controller, and hook it up again. If not, get a wireless controller. They are way better.
Posted on Dec 28, 2008
2004 Chevy Express 1500 keeps blowing trailer light fuse
If you're only blowing the fuse while the trailer is plugged in, the problem is in the trailer/wiring. This takes into account that the truck has a factory installed 7 way receptacle. If that's not the case, the problem can be in the incorrectly wired truck and the trailer is ok.
On the truck, looking into the 7 way receptacle should be as follows.
Top left=Tail Lights
Top right=12v steady source/charge line
Left middle=Left turn/brake
Right middle=Right turn/brake
Left bottom=ground
Right bottom=brake controller output
Center=reverse lights if your trailer is equipped.
Your trailer plug should mirror this.
This is the standard.
Oct 25, 2013 | 2005 Chevrolet Suburban
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
Just keeps flashing not doing any thing eles
is it wireless. if so press the little wireless button in the front of the controlle(between the top triggers) and push the same looking button on the 360. they should sync. if it's wired, then you might have a bent pin in the plug wires or the controller is no good.
Sep 04, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wired controller glows green for 2 secs then shuts off
Microsoft software is usually very good about finding mods within their systems. Since you have repaired a wire, it might somehow think it's been modded.
Double-check your repair work, if you used a soldering iron, it could have attached to another wire -causing a short (faking a mod). If you just twisted and taped it, you might want to consider a better fix.
Aug 01, 2009 | Microsoft Xbox 360 Controller
Tow plug
Check and clean all the ground connections.It sounds like a ground issue if they come on with the headlight switch.
May 28, 2009 | 2005 Ford F 250 Super Duty
My controller won't connect to my 360
hello dasuperman..
try this..
1. since you are using a WIRED CONTROLLER, and its not conencting,try using a different controller to further isolate you issue.
2. if the other controller worked,then most probably the controller that your trying to use is not working, try calling xbox customer support for possible replacement of ur accesory.
3. If the other controlle still doesnt work,then you hav eto send your console in for repair, you can process a repair to the website service.xbox.com,click on "repair my console" or if you want to be assisted by xbox support reps.call xbox support hotline,, 1-800-4-MYXBOX.
May 17, 2009 | Microsoft Xbox 360 Console
My PS3 wireless controller does not come on
change the batteries or either there's interverence from another product.
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
My microsoft xbox 360 wired controller won't work. The upper left and lower right corner lights blink one and then about 10 seconds later all the lights blink but don't configure to a designated player...
The controllers are probably broken. If i were you i would try contacting xbox customer support to see it they could give you a new controller. Im pretty sure that the controllers run off of the same warranty as your console.
Dec 31, 2008 | Video Game Consoles & Games
Xbox 360 wired controller doesn't work
hello ill give you a tip mabey push it in harder or check the cabel are in tightly
--full str pka
Joytech
Sync the controller. Press and hold the sync button on the controller, and go over to the Xbox 360 console, and press and hold the Xbox 360 console sync button. Wait for a few seconds or until the controller lights stop blinking. Then test out the controller.
Oct 12, 2007 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
291 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
