Question about Yamaha Full-Size Keyboard
Psr e303 yamaha double sounds
When I hit the G note below middle C it will do a double sound. The first sound is normal, even if given a soft touch but when I begin to release the G note there is a real loud note. IT only did it once in a while at first but now it does frequently. I hope it is just a dirty contact of some sort.
  • imageplus1 Jan 05, 2009
    No I don't cover it but I will start to. I tried blowing off the keys with a can of air. It seems to have helped a little but it still does it.
    Thanks for the information and help
  • 4 Answers
Do you cover the keyboard when not in use as small particles of dust can make their way in between the keys?
You can try blowing any obstruction out with a can of compressed air, may solve your problem.
As I'm not familiar with this Model, does the keyboard have 'touch response' on board? If so there will probably be a 'Contact' strip made out of tubular rubber under the keys and this can sometimes 'burst' especially on a certain key that is played most of the time. For example if you play mostly in the key of 'G' or keys that use that note....
Hope you find this helpful......
Posted on Jan 01, 2009
My Yamaha psr e303 all keys from bass side stop playing what can I do?
You might have the accomp switch turned on?
If not try holding down the highest key whilst turning the keyboard on, this will start a factory reset.
Sep 18, 2016 | Yamaha Music
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
YAMAHA PSR 9000 D NOTE VERY LOUD INTERMITANT
If you have any key note problems with your yamaha psr 9000 and need It repaired contact a qualified engineer at stephenhns5@gmail.com
Jan 28, 2013 | Yamaha Music
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now...
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Apr 02, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
I want to reset my keyboard psr E303
Press the Portable Grand button once. Here is a link:http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail.html?CNTID=49083
Sep 20, 2010 | Yamaha Music
Looking for a replacement volume control module for psr e303
You can obtain these from Yamaha Music Spares Dept in your country.
Go to the following Yamaha site link and choose your country
Select Musical Instruments - Support and the contact details will be displayed.
I just used them to by some parts for a Clavinova and they were in stock, accepted credit cards and delivered within 24 hours.
Oct 18, 2009 | Yamaha Full-Size Keyboard
Yamaha Keyboard PSR 730/630
no sound on all the g and gflats except the highest octave
Aug 04, 2008 | Yamaha Portable Keyboard with 61...
Yamaha Full-Size Keyboard Logo
236 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
