My computer wont turn on when i plug the 2x2 connector into the motherboard
  • 53 Answers
Double check every conection in the computer
Posted on Sep 17, 2009
My power supply has a 4 pin connector to the mb,, but my gigabyte mb has 8, which 4 do I use?
The motherboard can support a 2x2 (4 pin) or 4x2 (8-pin) connector. The motherboard employs a foolproof design, as the socket on the motherboard is keyed to prevent you from installing the 2x2 in any position other than the correct one. The image below was extracted from page 24 of the manual.....you plug should be in pins 3,4,7,and 8.
5gdyeavkqd8hdkhmptocjzpg0wkeeaegjyamakqf5acalia8apatkaycugdwakbkqbwbsaviaqepahgbiccgdackbeqagjsapakqe5agalia8ajaskacauglyaebkqb4asaniawap+x9q3vizrp3bpwaaaabjru5erkjggg==
Jan 19, 2012 | Gigabyte GA-MA785GM-US2H Motherboard
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
Intel D945GCLF - No post, No video Signal
Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
Sep 22, 2009 | Intel D945GCLF Motherboard
Computer wont work when 2x2 connector is plugged in
sounds like a cpu problem, or a failing power supply.
Dec 28, 2008 | Intel Motherboard
Gateway Intel 850 Socket 478 ATX Motherboard Power Supply
Please use the following as a reference: ATX12V Power Supply Design Guide, http://www.formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf
Sections 4.5.2 and 4.5.3 (Page 38) list the signal and wire colors for the +12V2DC (2x2 pin) and Peripheral (Molex) Connectors. Figure 11 (page 36) shows diagrams of the connectors and pin-outs for reference.
Most likely, you are looking for the 2x2 pin connector; pins 1&2 are common (black wire), pins 3&4 are +12V2DC (yellow wire w/black stripe)
Dec 14, 2008 | Gateway (4000782) Motherboard
My computer won,t turn on
2x2 or 2x4 Power Connector Not Plugged In
If the power supply cable with the 2x2 connector or 2x4 connector (depending on your desktop board), is not plugged into the 12V processor core voltage connector located near the processor socket, the system will not boot up. You will see lights onboard and on the chassis front panel and the processor fan will spin, but nothing will appear on the monitor. See figures below for cable placement.
  • Make sure the fans on the processor are connected properly and running.
  • Make sure that the thermal interface material or the thermal grease is applied to the processor properly.
  • Make sure that the power supply fan is running properly and any other external case fans are running properly.
  • Make sure that the air intakes for the external fans are unobstructed and have at least several inches away from walls and other items.
  • Oct 08, 2008 | Gateway 3250S PC Desktop
    Computer stopped working - I see a spark when I plug onto motherboard
    the spark you see is a shorted power socket on the MOBO, the spark is shutting down the power supply for protection. You need a new board.
    May 19, 2008 | Intel D945GTP Motherboard
    Computers & Internet Logo
    65 people viewed this question
    Alun Cox
    David Payne
    David Payne
