Question about Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
Martian sounding I do not have the manual for my walkie-talkies and when I first got them they sounded great. I recharged them and the batteries are fine, but now when someone talks you can't understand them. They sound like Martians! There are "mon" "chan/tone" "menu" and "call" buttons. Could one of the buttons make a difference? I can't seem to change it back. Thanks, Pam
  • Anonymous Apr 22, 2009
    same %$@!?%!$%@!#@%!$#@%!$@#!$%@#$!%@#$@$@#@$#$@!%@$%!@#!%$@#%!@!#
  • 127 Answers
Http://safemanuals.com/ please rate me so i knoe if i helped.
Posted on Jul 16, 2009
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
T5419 won't work
Sounds like you have a bad battery. Most rechargable batteries need to be replaced after 18 months of use. If your battery is newer than this, You have a defective battery.
May 15, 2014 | Motorola Radio Communications
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
Walkie talkie manual
Your best option is to throw these away and buy new ones.
Support Cobra Electronics Corporation
May 15, 2013 | Cobra FRS 70 (2 Channels) 2-Way Radio
Left walkie talkies with batteries in - wont turn on
need get battery our and spry CRC Cleaner to Battery contact cause they are rusted
Dec 17, 2017 | Radio Communications
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
One of my midland lxt 420 walkie talkies wont charge!!!!!
If it has rechargable batteries in it like mine does, the batteries have probably lost all of its life.. you can replace them.. if you dont have batteries, you could have a loose wire inside the walkie talkie that wont let it charge..
Jul 29, 2009 | Radio Communications
Charging Problem
You can ask the seller you bought the walkie talkie from.
Sorry, I don't speak English very well.
Dec 25, 2008 | Cobra Radio Communications
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
197 people viewed this question
Top Uniden Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
