I have a 1995 e150 it wont shift out of park unless the van is off ,the odometer stopped working and the brake lights.i also see the abs light is flashing.when i stert the van in nutreul and drive the trans shifts hard.any ideas what may be the problem?
SOURCE: ABS LIGHT ON, SHIFT LOCKED, NO BRAKE LIGHT.
If your brake lights don't work Its because you blew the fuse which Is located In the main fuse panel under steering wheel. Without break lights your rover will fire up nice but wont shift out of park until you replace the fuse. If your ABS Is acting up It Is also an easy fix. Disconnect the ABS from each wheel. You still got all wheel disc breaks that work great but no ABS. Your other option is thousands of $$. If your breaks are weak check your master cylinder and make sure you got enough fluid and that you are not loosing the fluid. If you notice you are leaking brake fluid because you have to keep filling it up but cannot find a leak anywhere. I bet I know where It is. Check your rear break lines and make sure one of them didn't get caught in your rear springs and pinched ever so slightly when you were doing dounuts In the snow.
Good luck,
SOURCE: 1995 ford econoline van speedo/trans
It is either the speed sensor, the wireing in between ot the speedometer module it self. The sensor sends pulse train signal to the speedometer module and there it drives the speedometer and is divided in frequency by about 7 and feed to the computer and the cruise control. When the signal drops the Engine management computer thinks the speed is real slow and raises the transmission pressure.
In the one I had it was a cold solder jooint on the bacjk of the speedometer module itself but this was the divided output and the speedometer itself still worked. The easyest part would be the sensor that mounts on the rear axile I believe and should cost less than 30.00 dollars. If not that thebn it's the wiring or the speedometer module electronics..
SOURCE: abs light turns on once in a while on my 1995 E150 conversion van
a bad wheel bearing will cause abs light to come on.
SOURCE: ABS Light and Parking brake light on
sounds like your vehicle speed sensor is going out. it's the modern equivilent of a speedometer cable. it tells the computer how fast your going which the computer uses to determine shift points, abs function, and speedometer readings. they usually act up a bit before they go out. it confuses the computer. normally located in the extension housing at the rear of the transmission where the spedometer cable would be on an older vehicle
SOURCE: 1995 ford taurus no speedometer, abs light, won't shift correctly
speed sensor needs replaced
